975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 03:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dyeing z rims
Author Topic: Dyeing z rims  (Read 2850 times)
  • Andy
Dyeing z rims
« on: January 08, 2013, 08:56 PM »
Hi all. I'm sure this has been covered before, but I couldn't find the exact answer in the sticky section. I've got some white zeds that i'm about to dye mid blue. Although the small tins of dylon dye have been discontinued and you now have to buy a 500g tin for about £50, there are a few sellers with some small tins still in stock. a few questions then:
How many small tins will i need to dye a pair zeds?
Or shall i just use rit dye instead? - if so how many packets?
**or if anyone wants to swap a white set of zeds for a dark blue set, please let me know***
NB: They are mike buff zeds, but the person who i got them off sanded the sides down, so the mike buff stamp is virtually gone.
Re: Dyeing z rims
« Reply #1 on: January 08, 2013, 09:04 PM »
Don't use dylon Andy, use Rit dye, available off eBay.
You will need some salt, a wallpaper steamer, and a big plastic bucket, bigger than 20" in diameter. :daumenhoch:
  • Andy
Re: Dyeing z rims
« Reply #2 on: January 08, 2013, 09:10 PM »
Thanks Dan. So Rit will work ok then? I've used it to dye grips before. I'll check out the rit colour catalogue now. Is it about 3/4 packets per set of rims? (adding just enough water to cover them of course).
Re: Dyeing z rims
« Reply #3 on: January 08, 2013, 09:19 PM »
I used 2 packs of rit and 2 tubs of salt to do 2 yellow hoops black.
I put the salt and rit in first, then the hoops. Then I coveted them with multiple kettle fills of boiling water. Use a stick or bamboo cane to agitate the powders thoroughly, then whack the end of the steamer in to maintain the working temp for the solution. Remember to keep stirring the solution about every 15 mins or so, and use the stick to turn the hoops over to get an even colouring.
This is purely based on yellow to black.
In your case, I would start by using 1 pack of dye to achieve your desired blue, or possibly take them out of the dye when the times right and they have reached the desired shade.
I took 3 hours doing my black ones.
  • Andy
Re: Dyeing z rims
« Reply #4 on: January 08, 2013, 09:21 PM »
fantastic, thanks for the advice  :)
Re: Dyeing z rims
« Reply #5 on: January 08, 2013, 09:29 PM »
dylon will produce the old school colours - rit has new colours that some times don't match bitd  ;)
Re: Dyeing z rims
« Reply #6 on: January 08, 2013, 09:32 PM »
Re: Dyeing z rims
« Reply #7 on: January 08, 2013, 09:35 PM »
Andy, I have 2 tins of Madonna Blue if you want them? :daumenhoch:
  • Andy
Re: Dyeing z rims
« Reply #8 on: January 08, 2013, 09:37 PM »
madonna blue is the colour that i'm after Dan. PM sent!
  • Andy
Re: Dyeing z rims
« Reply #9 on: January 08, 2013, 09:40 PM »
i think madonna blue is the one. I need them to fit in with this. Looks like a good colour match as long as i leave them in the dye for a while?....
Re: Dyeing z rims
« Reply #10 on: January 08, 2013, 11:05 PM »
Madonna Blue is what you are after, But remember - when looking at the item wet in the dye solution it will look darker by about one to two shades
volume of water % to dye will also determined the colour shade - this means the shape of the item you are dying in will also effect the dying process  ;)
cheers B  ;)
spyderpit13
Re: Dyeing z rims
« Reply #11 on: January 10, 2013, 07:51 PM »
Now that, looks like its gonna be a bite and.  :daumenhoch:
  • Andy
Re: Dyeing z rims
« Reply #12 on: January 10, 2013, 08:47 PM »
Thanks Tony  :). Sounds like you've got a few on the go at the moment. Did you get that ripper? Have you bought a kuwie as well for an E.T rep? Looking forward to seeing em! See you at the Leeds ride  :daumenhoch:
Offline Kaner
Re: Dyeing z rims
« Reply #13 on: January 10, 2013, 10:22 PM »
Here is my how not to do it thread!  Fookin Dylon did my nut!
http://www.radbmx.co.uk/forum/index.php'topic=101952.0
Re: Dyeing z rims
« Reply #14 on: January 10, 2013, 11:19 PM »
here is a old thread of mine that might help a bit  ;)
the gorden ramsay way of dying wheels
take 1 set of OGK's - slightly faded
wash
pick out any dirty bits missed
scrape off any brake marks
bleach
hot water
salt
dye
put in and leave for 24 hours - turning and stiring every so often
cover
take out and wash in cold water - then dry
now ready to serve - i mean ride - DONE
cheers B
Re: Dyeing z rims
« Reply #15 on: January 10, 2013, 11:32 PM »
Nice one Bendy. :4_17_5:
When you say you have to turn and stir over 24 hours, do you get up during the night to do this? ???
Re: Dyeing z rims
« Reply #16 on: January 11, 2013, 12:04 AM »
 ;D  I just always go to bed late
it's just a case of the best time for it to soak in, is when the water is the hottest - and keep the solution moving will coat the rims/mags better than it just sinking to the bottom  ;)
  • Andy
Re: Dyeing z rims
« Reply #17 on: January 11, 2013, 07:24 PM »
Thanks for all the help. I'll get onto this next week.  :daumenhoch:
