975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 03:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing outer paint layers
Author Topic: removing outer paint layers  (Read 712 times)
antiquebmx
« on: January 07, 2013, 11:20 AM »
Hi
need some advice , I have an old frame which looks to have its original paint underneath 2 newer coats of paint
I tried briefly to remove just the outer layers of paint to leave the original, I used some white spirit. I only did a tiny bit of frame but looks like it will work but gonna be hard graft
Anyone done this successfully without too much hard work??
cheers  :)
Offline Dannywhac
  • return of the whac
Re: removing outer paint layers
« Reply #1 on: January 07, 2013, 11:29 AM »
I've used the new Nitromors (as it's sh1t) on a rag to remove overspray, just gotta be careful and take your time. It might take a bit of the 'sheen' off the original paint, but just Turtle Wax it afterwards  :daumenhoch:
« Reply #2 on: January 08, 2013, 03:14 PM »
My guess is if you cannot carefully pick off the paint then whatever you use to take it off it will damage the original finish to some degree, I wouldn't worry about taking off the original finish tbh, chances are it was painted over in the first place because it was rough...   ;)
