Cheers all, was trying to avoid the heat method as its a nice candy apple red frame. Citric acid might be a tryer
Take an old stem that doesnt really mean much to you, clamp it as tight as you can around the seatpost and then put a bar/tube over the quill end to give you some leverage. That little sucka should shift in no time....Or failing that, use the proven blowtorch technique that our good man adenough sported recently
Quote from: scott250 on January 04, 2013, 10:09 PMCheers all, was trying to avoid the heat method as its a nice candy apple red frame. Citric acid might be a tryer I have used it on a few rusty frames and its amazing how it shifts rust. If you have access to a vice it shouldnt be a problem at all if it doesnt just fall out
