975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  pipe lagging??
Author Topic: pipe lagging??  (Read 1146 times)
Offline dwain dibbly
pipe lagging??
« on: January 04, 2013, 08:46 PM »
is there anywhere that sells pipe lagging or similar to use for inside a frame pad
thats coloured? either yellow or white?
Re: pipe lagging??
« Reply #1 on: January 04, 2013, 08:49 PM »
I saw some yellow around a scaffolds set up - grab some and see ?
Big E
Re: pipe lagging??
« Reply #2 on: January 04, 2013, 09:20 PM »
Try Demon Tweeks matey,they sell roll cage padding that comes in all sorts of colours and a few different sizes. :daumenhoch:
Offline Robbo
Re: pipe lagging??
« Reply #3 on: January 04, 2013, 09:57 PM »
Local Homebase or Wickes will have some, I bought some for wrapping round a frame I posted once.  :daumenhoch:
Re: pipe lagging??
« Reply #4 on: January 04, 2013, 10:03 PM »
cheers guys  :daumenhoch:
Offline Andy68
Re: pipe lagging??
« Reply #5 on: January 05, 2013, 10:43 AM »
Let us know how ya get on fella....... all the aftermarket ones I have, the foam is pants!!!! Rotating handlebar pads does my nut in.........
Offline Glynnyboy
Re: pipe lagging??
« Reply #6 on: January 05, 2013, 03:18 PM »
If you look afound you will find you will be anle to get white, grey & black in the right sizes.
The coloured stuff is for scaffold/roll cages and too thick.
I asked Steve ages ago as he has done a little research into pad reproduction in his time.
He said the coloured stuff isn't out there.
I had a look anyway and found his research was sound.
Red, yellow, blue will leave you looking for old padsets as doners.
Some pretty cheap original old no name padsets do come up on eBay.com now and again . You just have to keep an eye out.
Re: pipe lagging??
« Reply #7 on: January 05, 2013, 03:30 PM »
Raleigh burner pads  :daumenhoch:
Offline Glynnyboy
Re: pipe lagging??
« Reply #8 on: January 05, 2013, 04:31 PM »
Red on the nightburner, not sure but the 2nd edition basic red burner with the velcro pads may have had yellow foam.
If you want blue it could end up been a costly exercise, at the moment i can only see seperates on ebay.com
Re: pipe lagging??
« Reply #9 on: January 05, 2013, 04:42 PM »
Does anyone have the foam internal and external dimensions to hand for bars and top tubes.... i may be able to source foam  ;)
