975923 Posts in 138954 Topics by 6388 Members - Latest Member: Scottchegg1980 April 01, 2025, 11:44 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Restoration of a white CW Racing frame
Author Topic: Restoration of a white CW Racing frame  (Read 2917 times)
Willevie
« on: December 09, 2012, 08:16 PM »
Hi - I have an early 80's CW Racing frame in mint condition which I would like to rebuild. I would like to try and make the rebuild as authentic as poss - but within a reasonable cost. It's not to ride - just to look at!  Does anyone know someone who can help with the rebuild , London based. Also have a Skyway and yellow GT that I would do the same with if the CW was a success.... Thx Will
Offline That Swan Guy
Re: Restoration of a white CW Racing frame
« Reply #1 on: December 09, 2012, 08:22 PM »
Which frame is it? What is the serial number. It'll either be on the outside of the right rear dropout (if it's early 80s) or on the bottom bracket (if its late 80s).
Willevie
« Reply #2 on: December 09, 2012, 08:33 PM »
Out of the 3 frames this is the only one that has serial numbers on it!
« Reply #3 on: December 09, 2012, 08:34 PM »
What is the CWs frame number?
Willevie
« Reply #4 on: December 09, 2012, 08:41 PM »
Where do I see that?
« Reply #5 on: December 09, 2012, 08:42 PM »
Willevie
« Reply #6 on: December 09, 2012, 08:51 PM »
Unfortunately there are no markings anywhere on the frame or forks
« Reply #7 on: December 09, 2012, 08:52 PM »
then how do you know it's a CW?
Post pictures of the bikes you have and the guys on here will tell you what you have actually got.
Willevie
« Reply #11 on: December 09, 2012, 09:29 PM »
Thank you .. Will work out how to do and come back to you. Thanks
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #12 on: December 09, 2012, 11:38 PM »
Don't think it'll be a CW then bud, someone correct me if i'm wrong, but they all had serial numbers on, mine did, do, have  :-\
« Reply #13 on: December 09, 2012, 11:43 PM »
Yes they all have, doesn't sound like it is a CW.
Pics will help
« Reply #14 on: December 09, 2012, 11:44 PM »
The GT should have numbers too!
  • Andy
« Reply #15 on: December 16, 2012, 09:15 AM »
Unless they were all nicked bitd. Not pointing the finger at you by the way! Looking forward to seeing some pics. Get some up of the skyway too. Would like to see the bottom bracket area where the serial no would have been
« Reply #16 on: December 16, 2012, 09:18 AM »
What he said ^  ???
