975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 03:47 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tuf neck power disc.
Author Topic: tuf neck power disc.  (Read 797 times)
Offline mattbloke
« on: November 27, 2012, 12:10 PM »
i seem to be having trouble getting sprocket bolts that will go through the outer holes on my power disc...
the normal sugino backing parts of the bolts (the 'nut' part) wont fit into the power disc on the outer holes, but do fit the inner holes.
am i missing something blindingly obvious, are there specific bolts, or do the holes need to be tickled with a drill?
would rather ask and look a berk than drill something that cant be un-drilled  :)
energiza
Re: tuf neck power disc.
« Reply #1 on: November 27, 2012, 12:20 PM »
think youll find that the threaded bolt part of the sugino bolts fit threw the top of the disc then the nut bit with the 2slots in fit the back of the actual chainring your ginna use.if that makes sence
Offline mattbloke
« Reply #2 on: November 27, 2012, 12:26 PM »
thought about that, but the back of the disc is recessed on the smaller holes for the nut part, and the alignment needs the chainring on the outside..
Offline Jamroll
« Reply #3 on: November 28, 2012, 12:08 PM »
Matt, specific bolts yes, I had the same problem with a tuff neck ring and power disk, thankfully Matt (Swivel) came to the rescue and sorted me the bolts your after.  ::)
Offline mattbloke
« Reply #4 on: November 28, 2012, 12:10 PM »
ah bollocks.... lol any idea what they are?
Offline MaD-RoK
« Reply #5 on: November 28, 2012, 12:35 PM »
I think I used plain alloy ones on this.
Offline Jamroll
« Reply #6 on: November 28, 2012, 03:47 PM »
Yeah Tuf Neck  :LolLolLolLol:
Offline mattbloke
« Reply #7 on: November 28, 2012, 04:04 PM »
