975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 08:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tight Spot..............
Author Topic: Tight Spot..............  (Read 1795 times)
Offline Andy68
« on: November 21, 2012, 11:01 AM »
Once again a fookin MEGA tight spot in the new chain on my latest build last night. Every build this happens!  :tickedoff:  All seems straight, spins nicely, lined up well, chain on, then sh*t.   I'm guessing if each component is even slightly out/bent etc then it's gonna happen.   ???
Offline thebigdog
Re: Tight Spot..............
« Reply #1 on: November 21, 2012, 11:04 AM »
Do you have a chain tool? Try pushing the pin through a nic ever so slightly either way you may find its a nads cock out.....ive had this a few times if the chains been split the pin may not be in its original place  :daumenhoch:
mattuknc
« Reply #2 on: November 21, 2012, 11:08 AM »
chain ring bolts too, if that's not on straight you end up with a nice oval rotation.  :daumenhoch:
Offline Dannywhac
  • return of the whac
« Reply #3 on: November 21, 2012, 11:08 AM »
I know you'll have checked but :)
Chain-line - all straight from the freewheel to sprocket?
Rear wheel aligned correctly?
Has the sprocket bolt (if they're 3-piece cranks) pulled the sprocket out of line slightly?
Bottom bracket in flush?
Sprocket teeth not worn?
Chain off the bike - all links move freely?
« Reply #4 on: November 21, 2012, 11:15 AM »
theres also the dreaded freewheel "float" that ya cant do f'all about. if ya spin back wheel you can sometimes see the freewheel bobbing up n down slightly, that doesnt help  ::)
Offline Andy68
« Reply #5 on: November 21, 2012, 11:23 AM »
Cheers chaps, I'll check all above tonite.  :daumenhoch:
Chain looks like a feckin washin line in one place when adjusted at the tight spot!! I will not be beat!!!  :crazy2:
Offline MaD-RoK
« Reply #6 on: November 21, 2012, 11:58 AM »
Go chainless.  :buck2:
Offline Waxintaxin
« Reply #7 on: November 21, 2012, 12:29 PM »
undo everything and let the chain find its correct alignment, then do it all up in the right place
simples
« Reply #8 on: November 21, 2012, 12:38 PM »
Do you have a chain, tool?
No need to call him a tool, he only asked for a bit of help.  :D
Offline thebigdog
« Reply #9 on: November 21, 2012, 12:40 PM »
In a MR.T kind of voice  :LolLolLolLol:
Offline Andy68
« Reply #10 on: November 21, 2012, 01:06 PM »
Quiet Adam, ya bum nugget!!!!!!!!!!!   :P
