975641 Posts in 138929 Topics by 6348 Members - Latest Member: Dannygee July 02, 2024, 08:16 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Stem to headset question
Author Topic: Stem to headset question  (Read 1239 times)
Offline Gary72
« on: November 18, 2012, 08:58 PM »
Would it be a problem fitting a stem so it sits on top of the headset without any spacers?? I cant think of a reason but cant recall seeing it done.  :-\
I know there are stems that have a built in race thet replace the top part of the headset.
Offline bobbbbsy
Re: Stem to headset question
« Reply #1 on: November 18, 2012, 09:02 PM »
you mean the locking spacers that hold the part with the bearing underneath ? if so no.. it ll loosen every time you look at it !
race is at the bottom on the middle of the forks ! not sure i read you right !  :crazy2:
Offline Betty
« Reply #2 on: November 18, 2012, 09:02 PM »
If it's a front loader it might hit the top tube when you spin the bars
2 minutes turkish...
Offline Gary72
« Reply #3 on: November 18, 2012, 09:07 PM »
Top loader stem, So hitting the frame wont be an issue.
Yep, You have me confused now.
Offline Dannywhac
  • return of the whac
« Reply #4 on: November 18, 2012, 09:10 PM »
Top loader so all should be good.
So long as you have the top part of the headset (the bit that the bearings sit against) then all's good - I run without spacers (although at the mo I've got one small one as I have a front load stem).
Offline Betty
« Reply #5 on: November 18, 2012, 09:11 PM »
With a top loader you'll be fine, might wanna chop the steerer down if you don't want spacers on top of the stem
Offline bobbbbsy
« Reply #6 on: November 18, 2012, 09:12 PM »
i totally missed the section it was in .. sorry fellas !  ::)
i wondered why betty was talking about selfish pot smokers !  :crazy2:
Offline oldtired
  • Dirty Old Man
« Reply #7 on: November 18, 2012, 10:00 PM »
on a 1 1/8 ?    the black n chrome bit under the stem is one piece ie the the top cap ,with a 1mm steel washer/ spacer,   but if the compression wedge sits above the frame when compressed then can see no reason why the top cap and washer can't be left out ,  aside from leaving the bearing exposed, if its a sealed bearing then no probs , semi sealed you'd just have to watch for dirt getting in .
 is it for the gingemobile Gary?
« Last Edit: November 19, 2012, 12:30 AM by oldtired »
Offline Gary72
« Reply #8 on: November 19, 2012, 06:42 PM »
Yep it's for the gingemobile Jim. I'll be leaving the topcap on. I could turn the stem upside down but dont like the look of it. Your pic has answered my question :daumenhoch:
LENNY-LENTINI
« Reply #9 on: November 23, 2012, 05:14 PM »
'Ello Gary
It's perfectly sound to run your stem ontop of an internal headset without the top cap.
As long as you've got the compression ring in there.
I run my BSD race stem straight on top of my internal headset to get the 8.6 bars just the right height.
Keep the Faith. see you at Nottm. L
