975755
TattooedYorkie
September 22, 2024, 03:09 AM
Crank advice needed
Topic: Crank advice needed (Read 468 times)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Crank advice needed
November 15, 2012, 06:58 PM »
Hey guys i'm looking to fit a set of dura ace cranks onto a bb shell with a width of 68mm.
Does anyone know what length crank axle i should be getting and would one of these do the trick?
http://www.ebay.co.uk/itm/Bicycle-Bottom-Bracket-Cotterless-Crank-Axle-3A-3L-3P-3R-3S-3T-3SS-3U-5S-5SS-/200844251779?pt=UK_sportsleisure_cycling_bikeparts_SR&var=500120660975&hash=item2ec3401283
There is a thread on pg 2 of the stickies on crank index's but no one has added any info to it
Cheers all
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: Crank advice needed
November 15, 2012, 07:25 PM »
Ok blonde moment, the axles above dont have threads. One piece person usually, in case you hadn't guesses
Crank advice needed
