check the spindle isn't bent
If the hubs are not tightened up right, they can have a little wobble but i have found that they were made a bit like that, and have a wobble in them from the start - some are good and some are... just bad with a wobble
If it's not the spindle, here's the link to the press idea:http://bmxmuseum.com/forums/viewtopic.php?id=58417Failing that you can mount them to a set of forks, and using laggy bands around the fork legs and around the buckle try and pull them back over time.Never tried it meself.
