975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Square taper BB Help please !
Author Topic: Square taper BB Help please !  (Read 1024 times)
« on: November 07, 2012, 05:50 PM »
I have a crank set that needs a 15mm (measured across the flats on the sq taper) axle . The normal sq tapers for Sugino GT's/Takagi etc use a 13mm taper across the flats .
Can anyone point me in the right direction to a BB or even better has one that measures the elusive 15mm acoss the square taper flats for sale.
Any help would be appreciated  :daumenhoch:
Offline not johndub71
Re: Square taper BB Help please !
« Reply #1 on: November 07, 2012, 06:05 PM »
This might be a long shot, but try a Raleigh dealer with a workshop. They used something similar on their early mountain bikes, say a Lizard. It had a US bb with a three peice crank, also poss a Mustang too, but I had a lizard so know first hand.
Facebook/Fr35Hair
« Reply #2 on: November 07, 2012, 07:15 PM »
Thanks for the reply mate  :daumenhoch:  Can't see any bike shops were i live having anything but it's worth a try i
I was wondering if some other cranks used a similar size  :-\
Anyone else got any suggestions, pointers or solutions  ???
« Reply #3 on: November 07, 2012, 08:00 PM »
Did a bit of a search on here and i may have found something  :)
http://www.radbmx.co.uk/forum/index.php'topic=26518.0
Looks like the Redline 400 cranks came with the larger spindle (15MM across the flats possibly :-\) ...... could someone who has a set of these do me a big favour and measure the square taper for me please .
Thanks lads  :daumenhoch:
« Last Edit: November 07, 2012, 08:09 PM by NORTY40 »
« Reply #4 on: November 07, 2012, 09:34 PM »
When I saw the thread I knew you'd be after a square tapered  BB for either HLT or Sugino/Redline 400's Joffy
Hard to come by on their own mate , but now and again  :daumenhoch:
There's a guy called Cuckoo on here and Museum (Lee) , he did  excellent reproduction 400 BB's for about £75/£80 at the time .
 I think he's in the Far east , he's a good fella  :daumenhoch:
Frosty
« Reply #5 on: November 07, 2012, 10:06 PM »
Didn't Biagio also run up some copies too?
« Reply #6 on: November 08, 2012, 09:56 AM »
Thanks Christian  :4_17_5:   there not for a HLT crank or a set of 400's but something just as nice and rare too  :-X 8)
Sounds like it could be a long search  ::) :D Thanks for the pointers though , i'll try a wanted on here first and see what happens .
Do you know for sure or anybody else for that matter that the 400's axle measures 15mm across the flats ??
Thanks
« Reply #7 on: November 08, 2012, 09:57 AM »
Jeeeeeeeez they could be the best part of £150 then !!   ::)  :LolLolLolLol:
Offline john4130
« Reply #8 on: November 08, 2012, 05:16 PM »
i needed an axle for my redline 400s and searched for a couple of years before i found an original one, then about a week later cuckoo had them for sale. they look really nice too. i used a coke can to make small shims and a normal square taper axle till i found the correct one. worked fine too, it was nice and tight.
Offline Discostu
  • Two's Company
« Reply #9 on: November 08, 2012, 05:31 PM »
The alloy fusion cranks have a 15mm square taper.
I'm sure the group 1 steel cranks used the same bb and bearings.  :daumenhoch:
Frosty
« Reply #10 on: November 08, 2012, 07:46 PM »
what size are the pro-class spindles?
« Reply #11 on: November 09, 2012, 12:12 AM »
Thanks for the replys lads  :daumenhoch:
I had thought of that myself as a quick fix as they are only going on a carpet queen ...... it might have to suffice for the time being  :D Cheers John .
Do you know if the alloy fusion bottom brackets are available anywhere Stu  ??? or are they a pig to get hold of too  ::)
Not sure , i can find out though as i know 2 people who have sets of them  :daumenhoch:
