975755
TattooedYorkie
September 22, 2024, 07:31 AM
Pott's mod?
Topic: Pott's mod? (Read 1187 times)
sparkysx
Curb Endo
Pott's mod?
November 05, 2012, 08:42 PM »
Can you run one on these calipers? are you able to swap the top and bottom fixings around?
cheers
billstup
Team Owner
My life is Radbmx
Posts: I am a geek!!
Re: Pott's mod?
November 05, 2012, 08:44 PM »
Yep, I`ve altered some before
sparkysx
Curb Endo
Re: Pott's mod?
November 05, 2012, 08:53 PM »
how did you alter them, was it easy enough?
cheers
billstup
Team Owner
My life is Radbmx
Re: Pott's mod?
November 05, 2012, 10:38 PM »
Quote from: sparkysx on November 05, 2012, 08:53 PM
cheers
Just unbolt the 2 bits that unbolt , swap them over and refit them upside down
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
Re: Pott's mod?
November 05, 2012, 10:58 PM »
so it's not riveted on, the bottom lever, i take it !
sparkysx
Curb Endo
Re: Pott's mod?
November 05, 2012, 11:36 PM »
It certainly looks riveted on.
wildon
Flip-Whip
Re: Pott's mod?
November 05, 2012, 11:58 PM »
Yes it's riveted. You need to grind that one of, buy a front quick release from pork chop and have it pressed on. You'll need to change the adjuster for a front too.. If you want to do it properly that is
not johndub71
Look Back
Re: Pott's mod?
November 06, 2012, 10:37 AM »
I drilled mine off.
Facebook/Fr35Hair
john4130
Look Back
Re: Pott's mod?
November 06, 2012, 05:35 PM »
leave the quick release on and stick a normal adjuster through it, then just stick a pinch bolt where the top adjuster was.
Pott's mod?
