975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Best way to polish alloy
Author Topic: Best way to polish alloy  (Read 1212 times)
Offline Hmoon27
« on: September 26, 2012, 09:06 PM »
Ok I've got a load of survivor parts, rims, stems, cranks etc that are dull as Fook alloy.....
What's the best way to polish them up?
I don't have a polishing wheel by the way. Would a polishing mop on a drill do it? Do you use compound etc?
Cheers boys  :10_2_12:
Re: Best way to polish alloy
« Reply #1 on: September 26, 2012, 09:12 PM »
the best way is not to over do it  :daumenhoch:
bit of Autosol & a rag  :)
Offline not johndub71
« Reply #2 on: September 26, 2012, 09:28 PM »
Final coat of Autoglym Super resin protects too
Facebook/Fr35Hair
deeman
« Reply #3 on: September 26, 2012, 10:14 PM »
x2 :daumenhoch:
Offline CustardLips
« Reply #4 on: September 26, 2012, 10:18 PM »
Peek Polish and a rag (good stuff) !  :daumenhoch:
"WWG1WGA"
dj-paul-c
« Reply #5 on: September 26, 2012, 10:53 PM »
autosol is more abrasive than peek
but both have advantages
Offline midschooljon
    • Make Your Bones
« Reply #6 on: September 26, 2012, 11:06 PM »
Hot water, dish washing liquid, and a scotch pad.  :daumenhoch:
If you want original finish that's the best place to start. If you still aren't happy after that then try a little polish. People take to polishing parts too quickly in my opinion, and the bits just look over restored in the end. You will be surprised how good things come up with a bit of hot water and soap. :)
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
« Reply #7 on: September 26, 2012, 11:20 PM »
:coolsmiley: PEEK :daumenhoch:
deeman
« Reply #8 on: September 26, 2012, 11:23 PM »
peek is chrome polish,not as abrasive as autosol :daumenhoch:
« Reply #9 on: September 26, 2012, 11:39 PM »
he hasn't said what finish he wants
scotch pad will bring some bits up but can also dull some down
autosol will polish up but can leave hair lines in parts which will catch in certain lights
peek will polish up and also if enough elbow grease used will be a mirror polished look
scotch pads will give different looks depending on how fresh/used it is
cloths used will also give different finishes - tight pattern cloths can get a build up on them - loose pattern cloths (car cleaning cloth) can give a good finish as it can shift paste around better
Offline kev-s
« Reply #10 on: September 27, 2012, 04:34 AM »
brasso is good, buy the wadding in the can one not the liquid one, readily available at your local asda/morrisons/tesco etc...
« Reply #11 on: September 27, 2012, 09:36 AM »
t cut
Facebook/Fr35Hair
Offline kalex
« Reply #12 on: September 27, 2012, 10:11 AM »
this is what i use first
