0 Members and 8 Guests are viewing this topic.
I walked past that bike last week at Eurobike in Germany, I should have had a gander! Adding 25mm at the dropouts would have to make the stays flare out as I said and that'll be a nightmare for crank clearance. I'll see if that bike is at Interbike and have a proper look.
Is Roger running a bloody hydraulic disc in that pic...??!!!
Would he just not run a longer axle...?
Quote from: Devilock on September 09, 2012, 11:18 PMWould he just not run a longer axle...? You lost me?
Quote from: dingobmxer on September 09, 2012, 09:31 AMI had Odyssey Xtro forks and hub set up on my cruiser and it was noticably stiffer especially on the gateDingoReally Ding? What torsionally? I need to have a ride I reckon.....
Wow Dingo, I heard the Renthals were really good, obviously not! Still you haven't experienced flex until you've had a set of Galindo's!
Quote from: gossa on September 10, 2012, 08:02 AMWow Dingo, I heard the Renthals were really good, obviously not! Still you haven't experienced flex until you've had a set of Galindo's!Had a set of those on a build a few years ago, plastic crossbar with holes in! flexed like spaghetti lolDingo
Quote from: dingobmxer on September 10, 2012, 05:02 PMQuote from: gossa on September 10, 2012, 08:02 AMWow Dingo, I heard the Renthals were really good, obviously not! Still you haven't experienced flex until you've had a set of Galindo's!Had a set of those on a build a few years ago, plastic crossbar with holes in! flexed like spaghetti lolDingoThey are a lot better than that now Mark, I`ve had a set of Renthals on my cruiser all year and they`ve taken quite a battering, half the weight of S&M and almost exactly the same height and angles
Not sure on my thoughts on the thru axle malarkey yet,would bigger cones on 10mm axles improve stiffness? As for 31.8mm clamping area on bars/stems,is it really something that is change for the sake of it? Sure it`d be strong but most bars are butted/heat-treated these days.Looks like SpeedcoIntenseSinzPromax are all over everything,be nice to see more of other manufacturers BMX stuff....Did one of their frames have a 1 1/8 to 1.5 stepdown headtube???
