976346 Posts in 138998 Topics by 6449 Members - Latest Member: boba fett September 11, 2026, 12:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cables and rotors help
Author Topic: Cables and rotors help  (Read 1630 times)
Sheriff69
« on: September 04, 2012, 09:20 PM »
I have read quite a few threads regarding lubeing cables when using a rotor, can someone recommend some lube to use (waits for someone to type slide & glide ;D)
Offline Discostu
  • Two's Company
Re: Cables and rotors help
« Reply #1 on: September 04, 2012, 09:33 PM »
Remove the inner cables if possible. On non gyro units. And spray wd40 down the centre of the outer cable using the straw.
On gyro cables spray as much down each inner as you can get. Also spay all the joints.  :daumenhoch:
Sheriff69
« Reply #2 on: September 04, 2012, 09:39 PM »
Thanks Stu :daumenhoch:
Offline not johndub71
« Reply #3 on: September 05, 2012, 10:03 PM »
I pop some grease in the part of the cable where the two join to one too.
Facebook/Fr35Hair
Offline midschooljon
    • Make Your Bones
« Reply #4 on: September 05, 2012, 10:18 PM »
I use white lightening chain lube on gyro cables. It is a little more sticky then WD40 so coats them better and keeps them working smooth for longer. Spray lubes work well for a day or 2 but tend to not last nearly as long. Some grease in the join "capsules" is also a good idea.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Offline Robbo
« Reply #5 on: September 05, 2012, 10:29 PM »
I never lube before I stick it in, never any problems!  :P  :daumenhoch:
« Reply #6 on: September 06, 2012, 09:27 PM »
Fnar Fnar..
Facebook/Fr35Hair
