975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 10:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Alloy skyway spindle help
Author Topic: Alloy skyway spindle help  (Read 819 times)
Bathtub57
« on: August 26, 2012, 03:22 AM »
Im building up a copy of my bike from 1982, a Huffy Pro Thunder which I replaced most of the parts on.
The frame and forks are NOS and I'm planning to fit some alloy hub skyways.  As the skyways have a round spindle they obviously won't fit the forks so what are my option?
File the spindle - reluctant to do this, or..
Replace the spindle - where can I get hold of a replacement?
Any ideas???
Re: Alloy skyway spindle help
« Reply #1 on: August 26, 2012, 12:00 PM »
Right i have been resto'ing some of my hubs with a rebuild kit that i have - i have got a load of hubs/axles in and i take them apart and clean them up, they can be used to rebuild most standard hubs.
I have rebuilt up sets of Alloy hubbed Skyway mags with the cup bearings holders (not sealed bearing hubs) - you can replace most cup race bearing holder type mags and spoked wheels - although some might not fit so you will have to check first.
you can replace the axle to a standard fit size nut that is on a 10mm axle.
so i can do you a 10mm axle - a caged bearing race -  cone nuts that go against the bearings - the washer nut that sits tight next the cone nut - a bobble washer - a outside nut.
here is what the kit looks like
So you get
2x axle in black - 138mm long 10mm wide - standard thread size (not skyway size, so won't fit skyway nuts on)
4x caged bearing race in silver- 24mm across - 6mm deep - strong and well made.
4x cone nuts in black with removable skirt/shield, just tap it off or move up and down for a better fit - 17mm across 14mm deep on cone nut - 24mm across 2mm deep on shield.
4x washer nut in silver - 16mm across - 3mm deep
4x bobble washer in silver (well what would you call it ?) 16mm across - 2mm deep
4x outer nut in silver - 15mm across - 14mm deep
If you want a kit it will do both wheels - but please check rear drop out size of axle, as some can be wide (you can use your own rear axle with this kit if you need to fit wider )
i can sell a single half kit for one wheel if needed
kits will not be broken up for sale of individual parts
price's are
£10 posted for a kit (this is for two wheels)
£5 posted for a half kit (for one wheel )
if i get loads of members wanting this item, it may take a little while to sort the first load out - i have work and other members mags to restore + need to sleep and eat at some point !
please post in here and then a pm - if i don't get both you will miss out
they may not fit all, that is why i have given sizes -  so please realize I'm not perfect, just trying to help
GT STYLE 8mm cut side axle rebuild kit ~ Limited numbers !
£8 single kit posted
129mm in length - 10mm axle with the GT fork 8mm cut sides - this allows the axle to slip in to the 8mm axle gap on GT forks and such like.
bearing cage  25mm across 6mm deep cone nuts 15mm across 11mm deep -  cone nut washer 15mm across 3 mm deep - washer with groves on one side 19mm across 2mm deep - out side nut 15mm across 10mm deep - can also surply loose bearings on these.
pm me
cheers B  ;)
Bathtub57
« Reply #2 on: August 26, 2012, 03:27 PM »
Thanks chap, pm'd
Not sure why this didn't come up when I searched, maybe because it was stupid o'clock and I'd been at the stellas  :shocked:
« Reply #3 on: August 26, 2012, 03:32 PM »
cos it's not a sticky anywhere  ::)
