975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 03:47 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank and headstock bearing race removal how?
Author Topic: Crank and headstock bearing race removal how?  (Read 575 times)
tophat
« on: August 22, 2012, 09:55 PM »
Guys
My frame is going to the sand blasters so I have stripped it down ready but I cant remove the bearing race for the crank and the forks? I have heated the outer up a little but they still wont move?
Im talking about the thing the bearing sits in before you tighten everything up at the crank and the head stock.
am I right in saying these need to come out before sand blasting and painting etc? im sure they would if I was having it chromed so how do you get them out?
Offline Waxintaxin
Re: Crank and headstock bearing race removal how?
« Reply #1 on: August 23, 2012, 01:36 PM »
Hit them from behind with screwdriver / hammer combo , or take them to a local bike shop and they will press them out
Offline MaD-RoK
« Reply #2 on: August 23, 2012, 01:46 PM »
Couple of whacks around the clock with a screwdriver and hammer as said. BE CAREFUL not to do it near glass coffee tables, animals or old age pensioners as they sometimes ping out. Happy banging.  :daumenhoch:
Offline That Swan Guy
« Reply #3 on: August 23, 2012, 01:49 PM »
Rather than use a screwdriver I use an old seat post for the bb cups as it spreads the impact over more of the cup and won't stick in your leg after it shoots through cup when it's slipped off it. :LolLolLolLol:
tophat
« Reply #4 on: August 27, 2012, 09:05 PM »
Cheers guys. Thea bit more heat and the screwdriver worked in the end.
