975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 09:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  New brake pads and all bolts
Author Topic: New brake pads and all bolts  (Read 482 times)
lukethespookcoop
« on: August 22, 2012, 08:06 PM »
 Alright, can anybody tel me wher I can buy all new bolts washes and gibbons for brakes?, if there is any where!?, don't fancy too much more polishing!. Also, where can I get brake Pads and is there any blown up pictures of rebuilding brakes, I think I've got them right but could do with checking. They're weinmann 890's. Any input would be great. Thanks
Offline not johndub71
Re: New brake pads and all bolts
« Reply #1 on: August 22, 2012, 08:58 PM »
fleabay is full of pads. bolts are non no different from anything you can get from a good car parts. Brake pivot axle is as follows, so bare with me and see if you get me.
axle then spring, bronze washer, caliper arm, bronze washer and or plastic washer, caliper arm, washer nut, the domed nut, or in weinmann the other nut which has the plastic cover on.
tighten first nut to hold the caliper arms togethor so they move freely but with no forward movement, hold this nut tight with a 10mm spanner then tighten other nut upto it with another 10mm spanner thus locking them togethor.
Prob best doing this on bike.
Facebook/Fr35Hair
« Reply #2 on: August 22, 2012, 09:00 PM »
If your stuck for bronze or plastic washers, rule of thumb is a washer after spring, caliper arms then nuts.
Facebook/Fr35Hair
