975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 05:00 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP: MTB A-Headset Problem!!........PLEASE!!
Author Topic: HELP: MTB A-Headset Problem!!........PLEASE!!  (Read 681 times)
Offline Stace
« on: July 05, 2006, 10:16 PM »
Guys,
I know its not BMX but you guys care about an unhappy soul......please help!!  :'( :'(
Had my MTB frame re-sprayed, trying to put it back together and am having problems with the forks??........There is a small ring that I had to take off the bottom of the steerer on the old forks to put on the new, but it won't fit on properly.  How do I get it to fit???
Bottom
Also the top part of the headset doesn't look right but it is back to how it should be?
Top
All comments welcome!!
Thanks
Stace
Re: HELP: MTB A-Headset Problem!!........PLEASE!!
« Reply #1 on: July 05, 2006, 10:17 PM »
i use a old ring spanner to wack mine on and you got it the right way round
Offline Stace
« Reply #2 on: July 05, 2006, 10:27 PM »
I'm pretty sure its the right way round, its just won't budge....the little fecker!!
Does the top look right to you?
« Reply #3 on: July 06, 2006, 03:06 PM »
You could use a short length of scaffold pole to "whack" the lower race into place or as Lazychubs asys a large ring spanner or open ended spanner that fits snug over the top of the race (i.e. won't slip over it when hit with a hammer) or else use a very wide bladed flat screw driver and tap the race into place by tapping one side, then the other and so on working your way round the race.
Alternatively a trip to your local bike shop might be in order  :LolLolLolLol:
Marty
Offline Dingobmxer
« Reply #4 on: July 07, 2006, 07:20 AM »
Use the scaffold tube method or take it to a shop, it goes on square and unbent that way.
as for the top, it looks like you have a sealing topcap missing to me
 :) DINGO :)
Offline Stace
« Reply #5 on: July 07, 2006, 08:10 AM »
I think the top cap is there but I did think the same!  Doesn't look right but from what I've seen, its correct?????  Its rammed with grease which makes it loo worse but I will check it out!!
Thanks
Offline Stace
« Reply #6 on: July 07, 2006, 08:52 AM »
Just been on the Cane Creek website and your right it does look like the upper cover is missing.  I don't recall ever seeing one though!!
Any ideas where I could pick a replacement up as I'm confident I won't find it!!!
Thanks
Stace :daumenhoch:
