975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 01:12 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Slight movement after replacing a stem(s)
Author Topic: Slight movement after replacing a stem(s)  (Read 783 times)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« on: August 20, 2012, 06:57 PM »
Elp, i've just recently replaced 2 stems, a black for a blue Suntour Power Stem on a KZ1 and chrome for a red Group 1 on a FST. Now when I pull the front brake there is a slight bit of give and a knock noise - what have I done wrong as i've expertly replicated the problem on both bikes...  ???
Consistently not quite getting things right,
Chris  :daumenhoch:
Re: Slight movement after replacing a stem(s)
« Reply #1 on: August 20, 2012, 08:52 PM »
Have u got them both slammed down on the lock nuts ?  If there is a gap they will move a little  ;) there r raviations on quill diameters aswell which can be remedied by wrapping cut up beer can around the quill. But b very carefull cos when its cut its like a razor  ::)
Offline Discostu
  • Two's Company
« Reply #2 on: August 20, 2012, 09:08 PM »
Good advise there Steve. I would also check the headset hasn't come loose as the bearings settle into the cups after a bit of riding. Remember to take the top nut and toothed washer off to tighten up the top cone on a beartrap type headset. So you don't fook the threads on the forks.  :daumenhoch:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #3 on: August 20, 2012, 10:33 PM »
Cheers, I'll run through your advice tomorrow night, does drinking a beer count as a rehearsal?  :)
Chris  :daumenhoch:
« Reply #4 on: August 21, 2012, 02:02 AM »
practice makes perfookt  :D
