975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 06:04 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cut down bars
Author Topic: Cut down bars  (Read 1523 times)
Offline Gizmo
Cut down bars
« on: August 05, 2012, 06:07 PM »
 Hi got some bars which have been cut down , bout 1" off each side
Is there anything that can be done to get the right width again ?
Thanks  ;)
Offline glenboy
Re: Cut down bars
« Reply #1 on: August 05, 2012, 06:13 PM »
yes they can be done no probs i have some that darren kap did , might be worth pm'ing him
Re: Cut down bars
« Reply #2 on: August 05, 2012, 06:17 PM »
As a quick fix to ad around inch either side you can use a copper reducing plumbing joint and super glue it in. Never tell under the grips but i wouldnt go racing with them unless you brazed/welded the joint  :daumenhoch:
« Last Edit: August 05, 2012, 06:22 PM by oldschoolace »
Burner_Boy
Re: Cut down bars
« Reply #3 on: August 05, 2012, 06:17 PM »
Stick a piece of wood in each end, make a collar oit of sheet metal, weld and remove wood, puts sum grips on, or just jam the wood poles in and cover with grips and no one will know! Probablly wouldent do either of thoes as i just mase that up so quick answer, i dont know  :2funny:
Re: Cut down bars
« Reply #4 on: August 05, 2012, 09:39 PM »
if you want a proper job you can ride then send 'em to Phil Sazwall
he fixed mine a treat  :angel:
Offline Gizmo
Re: Cut down bars
« Reply #5 on: August 05, 2012, 10:16 PM »
thanks for the tips guys
Appreciated ;)
ill give the copper a go if not ill pm
the radster thx :)
Re: Cut down bars
« Reply #6 on: August 05, 2012, 11:16 PM »
Pics of Phil's work on my Hoffman bars  :smitten:
Re: Cut down bars
« Reply #7 on: August 06, 2012, 09:39 AM »
Thanks  ;)
I guess the answer is yes, but what is 'the right width'?  1" off each side isn't that much to be honest and hardly noticable, unless the bars were very narrow to start with.
what bars are they?  ???
Offline Gizmo
Re: Cut down bars
« Reply #8 on: August 06, 2012, 06:14 PM »
amazing job there , imm gona pm him
for a price :) thanks
Offline Gizmo
Re: Cut down bars
« Reply #9 on: August 06, 2012, 06:20 PM »
Thanks  ;)
there db pro bars , bit uncomforatable
To ride cut down
