975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 02:22 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Seat post tube too narrow.
Author Topic: Seat post tube too narrow.  (Read 1936 times)
rwleigh
« on: August 03, 2012, 01:01 PM »
Can anyone advise on the best way slightly open out a tight seat post tube.
I want to get this done before it goes off to Dan for it's new fluorescent green powder.  :)
Re: Seat post tube too narrow.
« Reply #1 on: August 03, 2012, 01:27 PM »
just put a flat end screw driver in it when you put you post in.
mileyboy
« Reply #2 on: August 03, 2012, 01:48 PM »
Have you checked the width of the post?
Offline Andy68
« Reply #3 on: August 03, 2012, 02:03 PM »
Gonna ask the obvious....... any rust inside seat post tube fella???
rwleigh
« Reply #4 on: August 03, 2012, 02:06 PM »
I can get the post in using a flat bladed screw driver and it is a 22.2mm post.
I just wanted to make it the correct size more permanently so i don't have to use the screw driver on fresh powder.
rwleigh
« Reply #5 on: August 03, 2012, 02:20 PM »
No it's very clean and rust free inside, it's just the slot that isn't as parallel as it used to be and therefore tight at the top.
Offline oldtired
  • Dirty Old Man
« Reply #6 on: August 03, 2012, 03:24 PM »
you can use an old post to open the gap up , bung it in so its just below the slot, preferably below the weld on the plate,   then force it backwards , use a clamp on loose to stop it spreading to far ,  better still if you can use some weight to force it back and the leave it a couple of days with the weight on it,  have used an old axle in the dropouts and a ratchet strap onto the seatpost to force the post back , left for a few days to let the steel move , on a raw frame you can use some heat to speed things up
« Last Edit: August 03, 2012, 03:33 PM by oldtired »
Offline Peter J
  • I have issues
« Reply #7 on: August 03, 2012, 03:29 PM »
Put the blade of the screwdriver inside a "cloth" dish cloth or one of them microfibre dusters (ask the Mrs  >:D )
and slide it in from the top with a gentle wiggle and ease it in to open it up
Bit like having bum sex with the Mrs don't just go stabbing in there or you'll knacker it  :daumenhoch:
rwleigh
« Reply #8 on: August 03, 2012, 06:36 PM »
Thanks for the advice guys, think i'll start with the screwdriver in a cloth option first.
By the way Peter, WAY TOO MUCH INFORMATION THERE! ::)
Offline rick1970
« Reply #9 on: August 04, 2012, 07:26 AM »
i reckon your problem is all that paint or powder inside tube get that stripped out and sanded before yer go prising with tools  :daumenhoch:
rwleigh
« Reply #10 on: August 04, 2012, 02:51 PM »
There is a little bit of overspray in there but nothing too serious, the slot definitely narrows towards the top though.
Doesn't show all that well in the photo.
« Last Edit: August 04, 2012, 03:51 PM by rwleigh »
« Reply #11 on: August 04, 2012, 07:43 PM »
The best way I have found on my Bodgin escapades  ::) is 2 Use a Rawshield in there and tighten it up it then pushes the tube out as it expands  :daumenhoch: Hardware store and a search 4 the closest size is the way 2 go  :P
rwleigh
« Reply #12 on: August 05, 2012, 11:51 AM »
I give in, what's a rawshield?
Photo, link...?
