975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 10:13 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spindle swaps... MKS Graphite for Shimano DX
Author Topic: Spindle swaps... MKS Graphite for Shimano DX  (Read 1092 times)
« on: August 01, 2012, 02:26 PM »
Just an inquiry as to if anyone knows if the pedal spindles from a pair of MKS Graphites will fit into some Shimano DX?
I have some 9/16ths spindles in some MKS Graphs that I want to swap for some 1/2 inch ones in Tom 'Thecaptian's Shimano DX... is that gonna work?
Re: Spindle swaps... MKS Graphite for Shimano DX
« Reply #1 on: August 01, 2012, 02:51 PM »
no help with the dx
but i have 1/2" mks graphite spindles that i would swop for the 9/16th versions ed :)
« Reply #2 on: August 01, 2012, 03:56 PM »
no help with the dx
ok - thanks Dave but I need to give Tom first shout.
Will get back to you if its a no on the Shimano swap  :daumenhoch:
« Reply #3 on: August 01, 2012, 04:23 PM »
Ed the 9/16ths are not original MKS spindles, they were from a set of Victor DX's off an old MTB Hootski got hold of so will work in the Shimmys. They don't have the distinctive ends where the spanner sits so Dave wo't want them I imagine.
Strip the one out and send them with the end cone and nut (don't mix them up!) to Tom to check and he can send back the set you need after he's 100% sure, or measure the one that is not in the pedal right now as it's the same.
Give me a call later tonight if you don't get what I mean, but the pedals were originally not a pair so I left one of the original 9/16" axles in one. You do have a pair of matching 9/16" to send Tom out of the Victors though wjen you strip the axles all out.
« Reply #4 on: August 02, 2012, 08:13 PM »
Not confused at all Spen  :uglystupid2:
