975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 07:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hutch Mag help please
Author Topic: Hutch Mag help please  (Read 1604 times)
Rob1
« on: July 27, 2012, 03:23 PM »
Hello all , I dug out my old OGK Hutch mags which I`ve decided to use on an old school build . After all these years the axle from the front one has disappeared . The hubs are marked Suzue Japan . Does anyone know where I can get the axle and balls and stuff from ? Would all the bits from a normal Suzue hub fit ?
Many thanks for your help .
The wheel in question...
Offline Peter J
  • I have issues
Re: Hutch Mag help please
« Reply #1 on: July 27, 2012, 03:31 PM »
I would have thought one the bog standard Halfords "front axel" kits would fit
They have the axel, cone nuts, bearings etc etc  :-\
I've used them before to rebuild a knackered hub  :daumenhoch:
« Reply #2 on: July 27, 2012, 10:32 PM »
Right i have been resto'ing some of my hubs with a rebuild kit that i have - i have got a load of hubs/axles in and i take them apart and clean them up, they can be used to rebuild most standard hubs.
I have rebuilt up sets of Alloy hubbed Skyway mags with the cup bearings holders (not sealed bearing hubs) - you can replace most cup race bearing holder type mags and spoked wheels - although some might not fit so you will have to check first.
you can replace the axle to a standard fit size nut that is on a 10mm axle.
so i can do you a 10mm axle - a caged bearing race -  cone nuts that go against the bearings - the washer nut that sits tight next the cone nut - a bobble washer - a outside nut.
here is what the kit looks like
So you get
2x axle in black - 138mm long 10mm wide - standard thread size (not skyway size, so won't fit skyway nuts on)
4x caged bearing race in silver- 24mm across - 6mm deep - strong and well made.
4x cone nuts in black with removable skirt/shield, just tap it off or move up and down for a better fit - 17mm across 14mm deep on cone nut - 24mm across 2mm deep on shield.
4x washer nut in silver - 16mm across - 3mm deep
4x bobble washer in silver (well what would you call it ?) 16mm across - 2mm deep
4x outer nut in silver - 15mm across - 14mm deep
If you want a kit it will do both wheels - but please check rear drop out size of axle, as some can be wide (you can use your own rear axle with this kit if you need to fit wider )
i can sell a single half kit for one wheel if needed
kits will not be broken up for sale of individual parts
price's are
£10 posted for a kit (this is for two wheels)
£5 posted for a half kit (for one wheel )
if i get loads of members wanting this item, it may take a little while to sort the first load out - i have work and other members mags to restore + need to sleep and eat at some point !
please post in here and then a pm - if i don't get both you will miss out
they may not fit all, that is why i have given sizes -  so please realize I'm not perfect, just trying to help
GT STYLE 8mm cut side axle rebuild kit ~ Limited numbers !
£8 single kit posted
129mm in length - 10mm axle with the GT fork 8mm cut sides - this allows the axle to slip in to the 8mm axle gap on GT forks and such like.
bearing cage  25mm across 6mm deep cone nuts 15mm across 11mm deep -  cone nut washer 15mm across 3 mm deep - washer with groves on one side 19mm across 2mm deep - out side nut 15mm across 10mm deep - can also surply loose bearings on these.
cheers B  ;)
Rob1
« Reply #3 on: July 29, 2012, 09:28 AM »
PM coming.
