975880 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 12, 2025, 06:28 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  25:9 gearing?
Author Topic: 25:9 gearing?  (Read 7581 times)
medved
25:9 gearing?
« on: July 25, 2012, 05:41 PM »
Can anyone explain the benefits of 25:9 gearing to me for a trails bike?
I have a dialled race frame that essentially i want to take to the park or trails and have a bit more fin. It currently has 44:16 gearing and wondered what the benefit was if any and whether i should consider changing over?
Re: 25:9 gearing?
« Reply #1 on: July 25, 2012, 05:46 PM »
25:9 will feel pretty much the same as 44:16.
To get the 44:16 feel, use the ratio of 2.75:1
Some say that having tiny gearing allows for easier coping clearance when riding into a ramp.
Not sure about that, unless you are literally riding straight in.
Maybe if you are trials riding it helps for getting over barrels.
It does look cleaner though.
And it's not a "new school" thing either.  Rob Ridge rode small gearing in 1990's.  I am sure he wasn't alone.
medved
Re: 25:9 gearing?
« Reply #2 on: July 25, 2012, 06:23 PM »
So aside from the grind/clearance aspect is there any other benefit other than looks?  Am I going to look a numpty turning up on 44:16 basically?
Offline Betty
Re: 25:9 gearing?
« Reply #3 on: July 25, 2012, 06:55 PM »
No and no
2 minutes turkish...
Offline john4130
Re: 25:9 gearing?
« Reply #4 on: July 26, 2012, 09:12 AM »
smaller gearing will be a little bit lighter weight with less material used and less chain links.
Offline gary67
Re: 25:9 gearing?
« Reply #5 on: July 26, 2012, 09:29 PM »
Who cares what you look like,fook em :knuppel2:
Offline HARORIDER
Re: 25:9 gearing?
« Reply #6 on: August 27, 2012, 05:41 PM »
agreed  :daumenhoch:
Mdbh
Re: 25:9 gearing?
« Reply #7 on: September 19, 2012, 10:51 AM »
28/9 is where it's at!!
evamedia
Re: 25:9 gearing?
« Reply #8 on: September 19, 2012, 11:25 AM »
I doubt it'll go unnoticed...
Re: 25:9 gearing?
« Reply #9 on: September 19, 2012, 12:38 PM »
lodge
Re: 25:9 gearing?
« Reply #10 on: September 19, 2012, 01:48 PM »
44 chain rings bend very easily and was a big problem on freestyle bikes in the late 80's and 90's, the micro chain rings are much more difficult to bend and as a bonus have much better clearance for disasters etc
Some believe you get more power from a big front sprocket (Sean Burns for one), personaly i'm not sure about that one.
Offline GavinDavis
Re: 25:9 gearing?
« Reply #11 on: September 20, 2012, 09:17 PM »
im running on 28/10 which is pretty fruity for quick starts, not as fast top end but still a good set up
GaryN
Re: 25:9 gearing?
« Reply #12 on: September 20, 2012, 10:30 PM »
Perhaps that explains the thinking behind the BSD 44T sprocket that is on my Hoffman D130, it's 10mm thick  :shocked:
Mdbh
Re: 25:9 gearing?
« Reply #13 on: October 15, 2012, 09:22 PM »
Wow your a real man! And must have buns of steal! :LolLolLolLol:
Offline GavinDavis
Re: 25:9 gearing?
« Reply #14 on: October 15, 2012, 10:06 PM »
 :LolLolLolLol: Damn right I am....These buns are bullet proof  :LolLolLolLol:
darksunday
Re: 25:9 gearing?
« Reply #15 on: October 23, 2012, 04:29 PM »
25-9 isn't a nice gearing, too stressed,too crunchy...
27-10
30-12 :smitten:
dodger
Re: 25:9 gearing?
« Reply #16 on: November 14, 2012, 12:09 AM »
28-11 here with a bash just in case i bail a grind or fancy a sprocket stall,i remember having a 10mm thick profile blackjack 1 faild feble stall and it was tacod  :2funny: that was £40 gone in all of 2 hours it was never really round anyway tbf
gordy
Re: 25:9 gearing?
« Reply #17 on: November 14, 2012, 12:07 PM »
As others have mentioned, the benefits of a micro gearing set up are . Reduced weight, increased coping clearance and a cleaner look. The down side is that chains can break more frequently, due to the chain having to wrap so tightly around the cassette. A larger gear on the back ensures it doesnt have to "loop around on itself".  This is the main reason why Racers haven't adopted micro gearing in the quest to reduce weight.
Mdbh
Re: 25:9 gearing?
« Reply #18 on: November 17, 2012, 06:38 PM »
Or just buy a good chain my half link shadow cost over £30 but never had a problem! And I've bashed it a few times! :daumenhoch:
Offline kev-s
Re: 25:9 gearing?
« Reply #19 on: November 17, 2012, 06:52 PM »
i run 25-9 and as olly says run a good chain you will have no porbs, i  also run a shadow v2 half link chain for a year now on 25-9 with no probs :daumenhoch:
Nana
Re: 25:9 gearing?
« Reply #20 on: November 23, 2012, 08:28 PM »
One thing no ones mentioned here ............you go riding park with 44/16 well it would be like going clubbing with flairs and platforms on
All about the street creed  ;D
While your at it wear ill fitting trousers and chain your wallet with a dog leash
Offline GavinDavis
Re: 25:9 gearing?
« Reply #21 on: November 23, 2012, 10:58 PM »
 :LolLolLolLol:....Give it a few years and the 44t will come back full circle and will be the best thing in the world to the newbies :) lol.
Offline Dingobmxer
Re: 25:9 gearing?
« Reply #22 on: November 24, 2012, 07:30 AM »
same here
Dingo
Offline region11
Re: 25:9 gearing?
« Reply #23 on: December 16, 2012, 04:09 PM »
I run a 30-12, because the hub i have wont take anything lower.  I do like the gearing. Although, not a lot of choice sprocketwise these days if you run anything over 28t.
Neil
gib66
Re: 25:9 gearing?
« Reply #24 on: December 20, 2012, 07:45 AM »
its all fashion maybe?
25 rings are good for clearance .when i started riding parks i was 44/16 and yes i hit the copings every time lol.i roll in not jump in .anyways i got down to 33 /14 which is tad odd gearing but the 33 cleared most things fine .the one problem with 25/9 is the pressure on the chain and the cassette is masssive compared with larger gearing so they wont last as long/fail faster .
race wise /dirt jump id be around the 33 to 36 teeth for sure look good and neat and not too much pressure on them
