975755
TattooedYorkie
September 22, 2024, 06:36 AM
Skyway Tuff 2
Topic: Skyway Tuff 2 (Read 831 times)
bbmac
Skyway Tuff 2
July 03, 2006, 06:35 PM »
How do you remove the rivets on Tuff 2 and what do you use to refit hubs
BrianP
Cherry Picker
Re: Skyway Tuff 2
July 03, 2006, 06:40 PM »
drill out the unrivetted end of the rivet (there are definitely posts on here explaining this in detail - came up a month or two ago)
I use M4 threaded stainless steel studding and M4 stainless steel nylock nuts on my rebuilds.
Bp.
bbmac
Re: Skyway Tuff 2
July 03, 2006, 06:48 PM »
Thanks now i can make a start on bleaching and dying tuffs from a very pale yellow / white back to yellow
selfpreservation
Re: Skyway Tuff 2
July 03, 2006, 07:06 PM »
cant you yus leave th alloy hubs in and grease them for protection see the how to section
Nosnod
Rockwalk
Re: Skyway Tuff 2
July 03, 2006, 08:30 PM »
Don't remove the rivets if you don't have to!
I had a pair of yellows in neat bleach for about 6 days. Just plaster the metal bits in grease and they will be fine. If they go a bit blackish don't worry as it polishes out.
bbmac
Re: Skyway Tuff 2
July 03, 2006, 08:39 PM »
one of the rear wheel rivets is missing so im going to totally refurb them ,
Skyway Tuff 2
