975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 10:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting grips heads up
Author Topic: Fitting grips heads up  (Read 1420 times)
Offline rick1970
« on: July 22, 2012, 06:25 PM »
i know this topic has come up a trillion times but i think ive found the answer   :LolLolLolLol:  Clutch and brake cleaner  :daumenhoch: its fookin awsome quick spray and they slide straight on and solid in next to no time  :daumenhoch:
nosher70
Re: Fitting grips heads up
« Reply #1 on: July 22, 2012, 06:28 PM »
hairspray.....
Offline rick1970
« Reply #2 on: July 22, 2012, 06:40 PM »
hairspray.....
  yep used that not as quick drying tho   :LolLolLolLol:
Sink
« Reply #3 on: July 22, 2012, 06:51 PM »
WD40 or the chearer poundland stuff, good spray, slid on and leave to dry :daumenhoch:
Offline kev-s
« Reply #4 on: July 22, 2012, 08:45 PM »
spit................................ its free, readily available and dries quickly if you dont use too much :daumenhoch: :daumenhoch:
Offline Devilock
« Reply #5 on: July 22, 2012, 08:55 PM »
Tears.
HEYWOOD BMX
« Reply #6 on: July 22, 2012, 09:44 PM »
 :) Stick a couple of sturdy zip ties through the grip.Slide the grip & zip ties over the bar then pull the zip ties out.
Offline Devilock
« Reply #7 on: July 22, 2012, 09:56 PM »
James, am I being blonde because I cant work out what you mean...?!!  ???
liddle145
« Reply #8 on: July 22, 2012, 10:03 PM »
With you on that one works perfect everytime   8)
Offline not johndub71
« Reply #9 on: August 17, 2012, 07:12 PM »
Rubber solution from a puncture kit.
Facebook/Fr35Hair
Offline Bigfrawg
« Reply #10 on: August 17, 2012, 07:47 PM »
Sheep semen , it's not baaaaaad
nosepickben
« Reply #11 on: August 17, 2012, 07:54 PM »
Dry wrestling. Man up boys...   ;D
« Reply #12 on: August 17, 2012, 08:00 PM »
lol
Facebook/Fr35Hair
Offline billstup
« Reply #13 on: August 17, 2012, 08:16 PM »
Lock on`s are the answer  :daumenhoch:
« Reply #14 on: August 17, 2012, 08:18 PM »
Goat seman is better for you  ;)
