is it 15mm AF not a standard 15mm ?? Just a guess
Quote from: Jaymz on July 16, 2012, 08:55 PMis it 15mm AF not a standard 15mm ?? Just a guessWhat the bleedin ell does that mean...??!!!
what doesn't fit..the internal of the socket onto the bolt or the outer of the socket into the crank arm?
Is it the outer diameter of the socket that is stoping it fitting into the crank arm? I had the same problem, had to grind down the socket, if you don't have the facilities to do this let me know, pretty sure mine is also 15mm, I'll post it to you as a loan.Bobby
Halfords do a slim range of sockets - I have one for this very purpose
