975755
TattooedYorkie
September 22, 2024, 01:27 PM
bearing cups sealed ?
Topic: bearing cups sealed ? (Read 1283 times)
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
July 12, 2012, 08:33 PM »
Got these - now the bearing is a 6003 and 17mm hole - checked the two axles i have a it doesn't fit - redline doesn't fit (which you will see in the link below)
so what does it fit ?
you see the same set up but the axle is different and has stoppers/blockers , what ever the fookers ?
http://bmxmuseum.com/forums/viewtopic.php?id=117900
info please
cheers B
Last Edit: July 12, 2012, 10:47 PM by BENDYCAT ELEVENTEEN
BENDYCAT ELEVENTEEN
Berm Worm
Re: bearing cups sealed ?
July 14, 2012, 01:08 AM »
Jon The Bassist
Flip-Whip
July 14, 2012, 01:37 AM »
It looks a bit like a BB used to fit a standard square taper axle for a 3-piece crank into a US size BB shell. I could be wrong though
BENDYCAT ELEVENTEEN
Berm Worm
July 14, 2012, 02:08 AM »
i have two squared axles and they don't fit over the threads ?
Jon The Bassist
Flip-Whip
July 14, 2012, 10:13 AM »
I was wrong then... maybe they'll know over on Vintage?
