975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 12:26 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Handle bars keep moving
Author Topic: Handle bars keep moving  (Read 943 times)
adeshere
« on: July 01, 2006, 01:59 PM »
WEll i've tightened the bolt up as much as i can, but as soon as i try any tricks, the bars move.
Do you think
a) i need to loose some weight
or
b) a new stem bolt wedge will fix it
Offline HUTCHMAN
Re: Handle bars keep moving
« Reply #1 on: July 01, 2006, 02:41 PM »
when you say the bars move,do you mean the bars move in the stem or the stem moves in the steerer tube?
« Reply #2 on: July 01, 2006, 03:59 PM »
b) i reckon
give stem bolt the tightening of it's life
if it strips then get a new one
duncan
« Reply #3 on: July 01, 2006, 04:37 PM »
It's not a Tuf-Neck style stem is it?
They have a stem bolt, but also a bigger hexagonal bolt below which needs to be really tight or the stem can slip round.
If you mean the bars move backwards and forward then the clamp's too big or the bars are too small (bars possibly crushed, or clamp-bolts stripped?).
« Last Edit: July 01, 2006, 04:41 PM by duncan »
weston
« Reply #4 on: July 01, 2006, 07:46 PM »
new stem for deffo unless your bars are as bad
adeshere
« Reply #5 on: July 01, 2006, 10:37 PM »
I really mean that the stem moves
« Reply #6 on: July 01, 2006, 10:42 PM »
I had this problem with a set of Haro Vectors bitd, to get around it I increased the height of the stem in the forks by about a half an inch as I found that the pressure of the stem bolt/wedge had caused the forks to either expand slightly or they wore into the forks at that point just enough to allow the stem to twist even though it was as tight as it was ever going to be.  Try lowering or raising your stem a touch and see if that helps, raising it and using a flex fighter might be the way to go.
Marty  :daumenhoch:
« Last Edit: July 02, 2006, 08:19 PM by martyC »
