975923 Posts in 138954 Topics by 6388 Members - Latest Member: Scottchegg1980 April 04, 2025, 02:57 PM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Who can Move AD Lugs ????
Author Topic: Who can Move AD Lugs ????  (Read 4283 times)
LENNY-LENTINI
« on: July 09, 2012, 04:53 PM »
'Ello Brothers
As usual with every S&M I've owned the AD lugs on My XLAF are too far down the chainstays.
Resulting in the rear wheel having to be nearly hanging off the end of the dropouts when using an AD style brake. (14.1" !!!)
Does anybody know of anybody who can remove my AD Lugs on my XLAF
And then re-weld them back on further up (towards the BB) the chainstay so I can slam the rearend. (13.65)
This bike is going to be ridden so needs to be done properly.
Cheers for your help, keep the Faith. L
thecaptain
Re: Who can Move AD Lugs ????
« Reply #1 on: July 09, 2012, 04:59 PM »
sawzall will be your man   :daumenhoch:
« Reply #2 on: July 09, 2012, 04:59 PM »
Len
Try pms to Phil 'Sawzall' and Steve 'Animal'
I'm about to get them to try and sort that busted DP  :)
1.Ed
Offline fugazi
« Reply #3 on: July 09, 2012, 05:22 PM »
Common problem on S&M's. You need a U brake with more room for the wheel. A Revenge Industries, or a Primo E brake should do the job, both are shorter in the brake adjustment slots & plenty of brake arm clearance to miss the tyre  :daumenhoch:
LENNY-LENTINI
« Reply #4 on: July 09, 2012, 05:30 PM »
Cheers Brothers
Will check some different calipers but i think they are about 1" out.
 I have just sent Sawzall a PM
If he can sorts it I'll post pics.
Keep the faith, L
Offline Munnyella
« Reply #5 on: July 09, 2012, 06:08 PM »
Hope the tape doesn't get damaged!!
MM
Offline Wayne Ryder
« Reply #6 on: July 09, 2012, 07:22 PM »
Goodness me, so the very people who make the bike with the problem also just so happen to make a massively overpriced solution?
I just love 'business'.
« Reply #7 on: July 09, 2012, 08:14 PM »
much easier to mod a brake than to mess with the frame.
Ive heard of a few people having problems but my fly brakes have always fitted fine.
Offline kev-s
« Reply #8 on: July 09, 2012, 10:00 PM »
as alex says fly chainstay brakes work fine on chainstay laf's as i had one on my old laf (r.i.p)
proper and ody evo brakes work fine on seatstay brake mounted s&m's too
Offline fugazi
« Reply #9 on: July 09, 2012, 10:36 PM »
I had to use a Primo E brake on My Blackbike as anything else just didn't come close to getting the blocks in line with the rim, and the wheel wouldn't go round as the arms were hard against the tyre.  The Revenge brake gave loads of clearance but wobbled about on the lugs too much for My liking.
On My Dirtbike I just about got away with an Evo2 with a 2" tyre.
elevensies
« Reply #10 on: July 10, 2012, 01:24 PM »
I have a ad990 on my laf, works perfect..
