975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:29 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck pro neck 2
Author Topic: Stuck pro neck 2  (Read 2680 times)
Offline Hmoon27
Stuck pro neck 2
« on: July 05, 2012, 09:11 PM »
Brought a bike of eBay (survivor) with a pro neck 2 stem on it and tange arx forks.
http://i1215.photobucket.com/albums/cc515/hmoon27/levyamahaburner003.jpg
 Stripped the whole bike , came to the stem and it just won't budge! Got the bolt undone and wedge is nice and loose , gave it a good spray with wd and left overnight, but no joy.
I've just turned it upside down ,taped up the hole on the stem and tied a rag around it so no fluid escapes , I've then completely filled the fork tube with 3 in one penetrant spray to see if this helps.
Don't really want to put the forks in a vice and give it a twist as I don't want to risk bending the forks?
Or am I missing a trick with the large bolt on the stem, what does this actually do? :idiot2:
What'd ya reckon boys?
rhinocharge
Re: Stuck pro neck 2
« Reply #1 on: July 05, 2012, 09:29 PM »
Try and get hold of some plus gas penetrating oil, WD40 does not work very well.
« Reply #2 on: July 05, 2012, 09:42 PM »
Sounds to me like the chrome on the shaft has rusted through and it's stuck in the forks fella. Plus-gas the outside of the stem shaft ie inside the forks and then grab the top of the forks in the vice at the brake hole and plenty of rags, put the bars back in and give it a twist :daumenhoch:
Offline kalex
« Reply #3 on: July 05, 2012, 09:58 PM »
doesn't the large bolt just holds the stem part to the stem shaft
Offline Hmoon27
« Reply #4 on: July 05, 2012, 09:59 PM »
That was my next move spen :daumenhoch:
I also took the bolt right out so the wedge fell out the bottom of the forks , but to no avail >:( thought if I could get the wedge out, I could try knocking the stem out from below?
Offline Hmoon27
« Reply #5 on: July 05, 2012, 10:00 PM »
Think your right mate :daumenhoch:
« Reply #6 on: July 05, 2012, 11:05 PM »
Put siome Coke down it (not the white powder - too exspecive  ;D) coke eats where wd40 doesn't - this will help shift the rust and they you can twist it free  ;)
« Reply #7 on: July 06, 2012, 11:19 AM »
SLEDGE HAMMERRRRRRRRRRRRRRRRRRRRRRRRRR  :knuppel2:
motomagII
« Reply #8 on: July 06, 2012, 11:39 AM »
ive used diesel too for eaxact same thing stem stuck in forks left it 2 days and it came loose easy after that
Offline Hmoon27
« Reply #9 on: July 06, 2012, 09:17 PM »
Cheers fellas :daumenhoch:
It's still soaking at the mo so I'll try it again on Sunday   :2gunsfiring_v1:
If not I'll go through the list :)
« Reply #10 on: July 06, 2012, 09:51 PM »
Yeah I've done this soak it for a good few days  :daumenhoch:
Offline Pooch
  • funny you should say that..
« Reply #11 on: July 06, 2012, 10:30 PM »
Remove the bars. Sit on it naked. Put the washing machine on spin and hold on tight!!! Works for me ;)
All of the above and a washing machine :daumenhoch:
Griff loves BUM..
Offline stuntmaster
« Reply #12 on: July 08, 2012, 07:26 PM »
duck oil is good as well
no1stuntmaster on instagram
Offline Munnyella
« Reply #13 on: July 08, 2012, 07:32 PM »
Just buy a new bmx, Halfords are doing the NEW at £69.99....
I don't know why we all bother at that price.
Just been and bought 50, I now have more than Kappy!!!
Result!
MM
Offline bobbbbsy
« Reply #14 on: July 08, 2012, 07:46 PM »
sorry !  :-\
