0 Members and 6 Guests are viewing this topic.
Depends how fancy you want to get mate.I've simply jammed my cable into the brake mid school style. All you need then is a knarp for t'other end. It's not the most sophisticated setup but it works.
Was there an earthquake happening while you took that pic?
This is it done using the adjuster that comes with the ad990's, the odyssey one is much neater.
Quote from: rodriguez on July 04, 2012, 06:54 PMThis is it done using the adjuster that comes with the ad990's, the odyssey one is much neater.This is the one you're getting Greg, I did say it wasn't pretty, but works, when I had a front brake, I did the same as Alex, but with an adjustable knarp the other side, it was scruffy, but not as bad as these.MM
