975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:15 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Just nabbed some G sport Homer hubs on eggheads bay
Author Topic: Just nabbed some G sport Homer hubs on eggheads bay  (Read 4259 times)
phatjimmy
« on: June 15, 2012, 06:13 PM »
Hello brothers i reckon ive had a result with these hubs, 2 complete wheels sporting the homer hubs front and rear for 32 of the queens english delivered!! Ive already lined up some 48h chrome rims ( also g sport ) just need to save up for my Holmes frame and pitchforks and ill be bustin some air again!! Have a good weekend all!!  :daumenhoch:
phatjimmy
Re: Just nabbed some G sport Homer hubs on eggheads bay
« Reply #1 on: June 23, 2012, 11:17 PM »
Ha Ha i should have asked if they were 14mm bolts  :idiot2:
Anyone know how to downsize the bolts on G sport Homer Hubs??
« Reply #2 on: June 23, 2012, 11:24 PM »
youll need new axle and bearings 10mm .dont go chopping
phatjimmy
« Reply #3 on: June 23, 2012, 11:26 PM »
Deffo wont be chopping!! Im glad they can be downsized 8)
Thanks again!!
« Reply #4 on: June 23, 2012, 11:28 PM »
just ask about ,im sure youll find some new internals in someones bike spares.
or even trade them at a later date.
Offline kev-s
« Reply #5 on: June 24, 2012, 08:19 AM »
you only need to change the axles, bearings are the same size in the 10mm & 14mm hubs, even both the axles outer diameter is the same (20mm) just one is drilled for 10mm and one is drilled for 14mm
(have a 10mm hub here and a spare 14mm axle so know they fit)
unfortunately ive not seen anywhere that stock 10mm axles, only 14mm ones and even those are getting thin on the ground now
you will prob be best off selling them on and try to buy some 10mm ones (im hunting for a 10mm front)
downside to selling them on is they arent worth much, roughly £20 per hub for the homers, even the original fat shaft mk1's i had only sold for £70 (should have kept em)
good luck and please dont grind the dropouts out
Offline kev-s
« Reply #6 on: June 24, 2012, 08:21 AM »
just had a thought, you may be able to get them helicoiled to take a 10mm bolt :daumenhoch:
or grind down the bolts to 10mm just near the head in the dropout area allowing you to just slide the wheel in and nip it up :daumenhoch:
« Last Edit: June 24, 2012, 08:25 AM by kev s »
Offline midschooljon
    • Make Your Bones
« Reply #7 on: June 24, 2012, 10:39 AM »
If you going to do this use a lathe and make sure its turned down evenly. If the bolt is ground even 1mm off centre at the dropout your wheel will sit as much as 3mm skew in the fork. Less accuracy obviously leads to bigger issues. My sport had a poor grind job on the axles (by the previous owner) and as a result the wheels point in all directions now. Do it properly on a lathe and it will be worth it.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Offline kev-s
« Reply #8 on: June 24, 2012, 11:39 AM »
gsports use bolts so if he fooks it up its only £2 for a new set of bolts from a hardware shop :daumenhoch:
phatjimmy
« Reply #9 on: June 24, 2012, 05:52 PM »
Thanks for the advice fellas I think ill have a hunt around and if i dont have any luck try an engineering place :daumenhoch:
Offline Dannywhac
  • return of the whac
« Reply #10 on: June 24, 2012, 06:31 PM »
Yep - nigh on impossible to find the 3/8" axles - George doesn't have any left either :(
Helicoiling them is an option, but from experience they get a bit wobbly going from 14mm to 3/8" - if ya do get a couple machined, put my name down for a front and rear n'all fella  :daumenhoch:
