975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 12:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Grip dying problems
Author Topic: Grip dying problems  (Read 2446 times)
Offline Devilock
Grip dying problems
« on: June 05, 2012, 11:07 AM »
A few weeks ago I decided to dye some grips for the first time & followed the stickie to the letter...I was even using the same grips in the same colour!
They did not dye!!  >:( Mark said he would try it for me so sent them off with another packet of Rit- they did not dye...!! I then sent him 2 more packets & he used them both...they did not dye...!!  :tickedoff:
What the cacking hell is going on...??!  ???
Offline Glynnyboy
Re: Grip dying problems
« Reply #1 on: June 05, 2012, 11:30 AM »
Read Christians comments on page 2 of that thread.
One of the grip dye threads on here ended up with one of the mods saying so 'basically ' grips don't dye.
They end up some sort of brown over time and the black starts to rub off.
Are the grips done in the thread still all that ?
Offline Jt
« Reply #2 on: June 05, 2012, 11:32 AM »
I don't two sets of .5's and some mashies.
Still nice and black.
Offline Glynnyboy
« Reply #3 on: June 05, 2012, 11:42 AM »
I was talking to someone at radchester last year with a set that had started rubbing off.
Not 100% but I think they were 5's.
( it may have been Sam but I had, had a few when I was been told the tale)
Offline Devilock
« Reply #4 on: June 05, 2012, 11:51 AM »
Did you follow the same process...?
Offline Jt
« Reply #5 on: June 05, 2012, 12:31 PM »
Dunno.
I Put a stickie up of my own.
I just chucked a load of Dylon ina massive pan,  filled it with salt, and boiled the fook out them for hours.
« Reply #6 on: June 05, 2012, 01:20 PM »
did you use a fixer ?
some rubber will not dye and some gets lucky
dylon works best on nylon, which it sticks to - seats have a mixture of plastic and nylon ~ this is why they dye well - grips don't have nylon in them
acetate can also be use to help it fix onto the grips
Offline Devilock
« Reply #7 on: June 05, 2012, 03:15 PM »
So what should I do/use to optimize adhesion...??!!
« Reply #8 on: June 05, 2012, 04:36 PM »
Theres some really good stuff on youtube on how to use Rit with acetone  :daumenhoch:
Offline Devilock
« Reply #9 on: June 05, 2012, 05:06 PM »
Nice one Ash, Ill check it out...  :daumenhoch:
