975834 Posts in 138948 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 08, 2025, 03:51 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Stupid question
Author Topic: Stupid question  (Read 418 times)
Offline Devilock
Stupid question
« on: June 03, 2012, 10:35 AM »
Can a 1 3/8 tyre be installed on a 1.75 rim for a low profile...? :-[
Offline Jon The Bassist
Re: Stupid question
« Reply #1 on: June 03, 2012, 10:40 AM »
No, fractional tyre sizes (eg 1&3/8 inch) fit a different diameter rim than decimal tyres (eg 1.5).
Re: Stupid question
« Reply #2 on: June 03, 2012, 10:44 AM »
Just saying Rich IF,,, it could stretch to the rim edge using a thin inner tube , aren't the internal radius larger on a 1 3/8 tyre/wheel  ???
so it would be baggy trying it over the rim anyway ,,I could be wrong  :-\
Edit  :D as Jon said too   :)
« Last Edit: June 03, 2012, 10:46 AM by Hunterdubber »
Re: Stupid question
« Reply #3 on: June 03, 2012, 10:55 AM »
A 1.5 would work nicely though :daumenhoch:
Offline Devilock
Re: Stupid question
« Reply #4 on: June 03, 2012, 12:13 PM »
Ok thank you Jon & thank you Chris...! :daumenhoch:
So 20 x 1 1/38 is bigger than 20inch...?? ???
Re: Stupid question
« Reply #5 on: June 03, 2012, 12:25 PM »
Yes, but it's the 20 x 1 3/8 that i actually nearer to being 20 inches.  Generally the metric sizes are only near their stated diameter when measured including a fairly fat tyre (eg 2.125 tyre).
Offline bobbbbsy
Re: Stupid question
« Reply #6 on: June 03, 2012, 12:31 PM »
20x1.75 wont go on a 1 3/8 rim at all ever so i would imagine the other way round is terminally wrong to !
xGoose
Re: Stupid question
« Reply #7 on: June 03, 2012, 12:37 PM »
Here my 2p's worth Rich, but not sure if it applies to ALL 20" rims & tires,
20X1-1/8 & 20X1-3/8 = 451mm diameter
20X1.50 & 20X1.75 = 406mm diameter (also 1.95, 2.20 etc. tires)
So only 451mm (fractional) tires will fit on 451mm rims and only 406mm (decimal) tires will fit on 406mm rims.
Be careful about what the frame is actually supposed to take as well as the brake positioning will also vary. For new school with lugs, some brakes like LDC have loads of adjustment so can be used on a mini / junior frame with 406mm  rims. For old school if you want to put a 451mm rim onto a pro frame you might need to find a smaller roadie style brake.
Hope that helps a bit ;)
« Last Edit: June 03, 2012, 12:44 PM by x-600se »
