975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 08:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  OS brake squeal ?
Author Topic: OS brake squeal ?  (Read 1294 times)
Offline steve69
  • aka. Steve Changa
OS brake squeal ?
« on: June 02, 2012, 03:17 PM »
I took my latest build for a test run today prior to next weeks London ride.
All's well except for horrendous brake squeal, of which i can only describe as 'the cries of a frustrated pig'   >:(
I'm running NOS Araya ano'd rims (not shine sides) with NOS Skyway Pro pads.
Obviously the pads were aligned with maximum contact to the rim, good stopping but really loud. I then pitched them over so i had less contact to the rim, still stopped well but just as loud. Cleaned rim with solvent, no change. Fitted another set of Pro pads, no change. Roughed up the braking surface of the pads with emery cloth to deglaze them, still no change.  :(
Fitted a set of Fibrax pads and the noise is now gone, but the down side (apart from not looking as good) is it doesn't stop as good :tickedoff:
So, the question is....      Has anyone overcome this problem (without having to ride with the noise for an unknown amount of time in the hope they will bed in)  ???
GaryN
Re: OS brake squeal ?
« Reply #1 on: June 02, 2012, 06:12 PM »
Do your pads/caliper allow you to toe the pads in so that the front/leading edge of the pads hits the braking surface first?
If so then that might help.
Offline steve69
  • aka. Steve Changa
« Reply #2 on: June 03, 2012, 11:51 AM »
Yes, i've tried pitching the pads in different directions with no better results  :-\
The odd thing is, i have Skyway Pro pads on most of my builds and there is some brake squeal from time to time but nothing like this.
Offline Pooch
  • funny you should say that..
« Reply #3 on: July 01, 2012, 02:15 PM »
I'll have some pro pads off you...  ;)
Griff loves BUM..
Offline bobbbbsy
« Reply #4 on: July 01, 2012, 02:20 PM »
what london ride ??  :shocked: >:(
Offline Betty
« Reply #5 on: July 01, 2012, 02:31 PM »
You've answered your own question in the first post
Squeaky brakes that work, or non squeaky brakes that don't work
Kool stop pads are good and don't squeak much  :-\
2 minutes turkish...
Offline oldtired
  • Dirty Old Man
« Reply #6 on: July 01, 2012, 03:07 PM »
caliper brakes?   tighten them up a bit ,get em as tight as possible without stopping the spring working,    its because the pads are grabbing the alloy not sliding over it causing the caliper to chatter ,  tis why the fibrax dont squeek,  harder compound,  you could also try some of the L shaped support brackets that rest on the frame they do help on caliper brakes, takes  the flex out of em under load .
Offline steve69
  • aka. Steve Changa
« Reply #7 on: July 01, 2012, 03:20 PM »
You was on it you plum  ::)
This thread was started last month  :LolLolLolLol:
Offline oldtired
  • Dirty Old Man
« Reply #8 on: July 01, 2012, 03:26 PM »
 :LolLolLolLol:   tinterwebs slow up here, were still on town gas  :LolLolLolLol:
Offline bobbbbsy
« Reply #9 on: July 01, 2012, 03:43 PM »
was i ? ! d'oh!!  :LolLolLolLol:
