975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 07:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Explain a coaster brake Tuff...!
Author Topic: Explain a coaster brake Tuff...!  (Read 6831 times)
Offline Devilock
« on: May 25, 2012, 11:55 AM »
Never used these before, so how do I install a freewheel?!    :-[
Does the arm just screw onto the frame? Screws were not supplied!
SteveD
Re: Explain a coaster brake Tuff...!
« Reply #1 on: May 25, 2012, 12:04 PM »
you dont install a freewheel - its a coaster brake - connect the arm to the coaster brake tab on the frame - if it has one - if not just use a jinged seat clamp and secure it to the rear stay ... just like bitd
Offline Devilock
« Reply #2 on: May 25, 2012, 12:10 PM »
Oh!!!  ;D So where do I put the sprocket for the chain...?!!
« Reply #3 on: May 25, 2012, 12:12 PM »
do you have the sprocket?  ???  it would seem to be missing
lovely looking tuffs though  :smitten:
Offline Devilock
« Reply #4 on: May 25, 2012, 12:15 PM »
Im afraid not Rob...so how do I install the sprocket?
« Reply #5 on: May 25, 2012, 12:18 PM »
firstly you need a compatible Suntour sprocket (i believe) then the outer ring comes off, on goes the sprocket (should sit into grooves) then back on with the clip....tighten up lock nut.
i think that's how they go but weired that it doesn't have one.  those Tuffs don't look like they've ever been near a bike!  :shocked:
« Reply #6 on: May 25, 2012, 12:21 PM »
Offline hotdog
« Reply #7 on: May 25, 2012, 12:24 PM »
Going off the diagram (3rd down)from the above link,you need part No.5,6 & 7
« Reply #8 on: May 25, 2012, 12:38 PM »
i think he just needs part No6 the actual sprocket, the other parts seem to be in place to me  ???   :-\
Offline hotdog
« Reply #9 on: May 25, 2012, 12:42 PM »
I can't see a dustcap,sprocket or circlip in his first photo mate.
Offline Devilock
« Reply #10 on: May 25, 2012, 12:45 PM »
I hope so...!!!  :-\ Thanks for the link!  :daumenhoch:
Something like this:
http://www.ebay.co.uk/itm/BENDIX-16-TEETH-BMX-COASTER-BRAKE-SPROCKET-SUNTOUR-/180891647337?pt=Cycling_Parts_Accessories&hash=item2a1dfb7d69#ht_500wt_967
Bru  :daumenhoch:
And thank you for that link!! Perfect, cheers!  :daumenhoch:
Offline Devilock
« Reply #11 on: May 25, 2012, 12:46 PM »
Oh shit dont tell me that...!  :(
« Reply #12 on: May 25, 2012, 12:51 PM »
Hmmmmm looks all there to me but i maybe wrong  ???  i can't see that there's a lot of room to fit much more to the hub??  ???
snav69
« Reply #13 on: May 25, 2012, 12:58 PM »
Yeah there should be a dust cover behind the sproket  :daumenhoch:
And as said you need a circlip  ;)
Rini has them  :daumenhoch:
« Reply #14 on: May 25, 2012, 01:02 PM »
No he is right Rob, you will need bit 5,6 & 7  :daumenhoch:
snav69
« Reply #15 on: May 25, 2012, 01:04 PM »
Here's what you want Rich  :daumenhoch:
Sorry NOT for sale as I need it myself  ;)
« Reply #16 on: May 25, 2012, 01:21 PM »
every days a school day
Offline Devilock
« Reply #17 on: May 25, 2012, 01:34 PM »
Come on Paul, Ill give you £8000!!!  :D
Oh well looks like Im on the hunt for those parts when I thought I could install the wheels today!  >:(
« Reply #18 on: May 25, 2012, 02:16 PM »
To make it a freewheel all you need is one of these
and a regular BMX freewheel to screw onto it.  It's a simple 15 min job to swap out the coaster part with the freewheel part and job done.
Offline Devilock
« Reply #19 on: May 25, 2012, 02:24 PM »
Could the coaster still be used in the same way?
snav69
« Reply #20 on: May 25, 2012, 02:27 PM »
No Rich  :daumenhoch:
« Reply #21 on: May 25, 2012, 02:27 PM »
No, once converted the coaster no longer works, there is another conversion out there that turns them into a freecoaster but I've not seen them in years and can't remember what they are called.  I think the other guys have shown what you need to get working though as a coaster brake
Offline Devilock
« Reply #22 on: May 25, 2012, 02:33 PM »
Ok thanks guys, Ill just have to post a wanted for those parts... :tickedoff:
brakedancer
« Reply #23 on: May 26, 2012, 09:51 PM »
i have the parts you need if your still looking as ive just converted my skyway coasters to freecoaster...
can pm you some piccy if you likey ;)
Offline Devilock
« Reply #24 on: May 26, 2012, 10:16 PM »
PM'd... :daumenhoch:
