975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  preferred choice of rim tape
Author Topic: preferred choice of rim tape  (Read 1032 times)
Offline kalex
« on: May 20, 2012, 06:52 PM »
i would just like to know what is the preferred choice of rim tape to use to protect the inner tube from the nipple/spoke end's. or do most not bother.
Offline Betty
Re: preferred choice of rim tape
« Reply #1 on: May 20, 2012, 06:54 PM »
Insulation tape  :daumenhoch:
2 minutes turkish...
Offline Munnyella
« Reply #2 on: May 20, 2012, 06:59 PM »
I make my own from knackered inner tubes, cut `em down, glue the ends, cut a valve hole.
I'm not a tree hugger, its about the only recycling I do!!
MM
Offline bobbbbsy
« Reply #3 on: May 20, 2012, 06:59 PM »
i use them 1 pound rubber liners
Offline kalex
« Reply #4 on: May 20, 2012, 07:10 PM »
all my spare tubes are all decent so i'll leave them.
i was thinking of duct tape but that'll leave to much gunk on the rim if i ever have to get to the spokes. plus i'd have had to cut the width down.
insulation tape sounds good or the rubber inners
cheers for the idea's
Offline bobbbbsy
« Reply #5 on: May 20, 2012, 07:12 PM »
« Reply #6 on: May 20, 2012, 07:25 PM »
RIM TAPE!
Offline kev-s
« Reply #7 on: May 20, 2012, 07:39 PM »
i use a good insulation tape
start at the opposite side of the valve hole,  go round once close to the rim wall as possible, then around again as close to the other side of the rim wall as possible then once around the middle and end where you started
then to open up the valve hole i use a multi screwdriver tool, the tool's end is the same size as the valve hole, just screw it through and it cuts out the insulation tape perfectly :daumenhoch:
Offline kalex
« Reply #8 on: May 20, 2012, 09:27 PM »
cheers chaps
it looks as if insulation tape is the way forward for me then.
