975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 05:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dirty Harry levers & V brakes
Author Topic: Dirty Harry levers & V brakes  (Read 638 times)
thesku11s
« on: June 25, 2006, 07:05 PM »
Hi,
Does anyone know if V brakes run ok with Dirty Harry levers?
My bars are huge and the time has come for my lever to enter the bend.
V brakes are way better than any U brakes ive tried so will want to hold on to them.
Thanks.
P.S
I will buy one from you if you have one spare.
Sanmarcopizza
Re: Dirty Harry levers & V brakes
« Reply #1 on: June 26, 2006, 08:06 AM »
I am doubting the Harry's will work. V-brakes need a specific type of lever with a bigger distance between the pivot and the cable end. You will probably find that the lever will hit the bars before it has adequately pulled the brakes against the rim.
Sanmarcopizza
« Reply #2 on: June 26, 2006, 08:07 AM »
As a thought you could probably bend your own lever so you could fit it on the bend.
« Reply #3 on: June 26, 2006, 09:58 AM »
v brakes are only better for skids.
u brakes are a better brake
