975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Body filler repair, before powder coat.
Author Topic: Body filler repair, before powder coat.  (Read 1328 times)
matsoki
« on: May 12, 2012, 01:36 PM »
I'm doing a cheap resto, on a Dyno Compe for the kid.
I've had the frame, forks and bars de-chromed, and there's a couple of dinks that need sorting before powder coat.
So the question is can I use a bit of body filler to blend them out, and will the power coat stick?
If not what can I use? I don't want to waste Dans time!
Cheers  :daumenhoch:
Offline Discostu
  • Two's Company
Re: Body filler repair, before powder coat.
« Reply #1 on: May 12, 2012, 01:42 PM »
No.
All repairs must be metal finished. With braze or silver solder etc
This is due to the high temperature that the oven works at when baking the powder. The filler will just burn off.  :daumenhoch:
Mdbh
« Reply #2 on: May 12, 2012, 01:42 PM »
I don't think ya can fella but I maybe wrong, but how about a few blobs of weld and grind them flat?
Offline kalex
« Reply #3 on: May 12, 2012, 04:56 PM »
i'd go with the above, and put a dab of weld then smooth them down. that way you'll never have to do them again. plus even if the powder would cover it, the filler would be blasted away when the frame is shot blasted prior to being powdered.
matsoki
« Reply #4 on: May 12, 2012, 05:05 PM »
Ok cheers guys.
I know a man, that's knows a man who is a welder, and I'm sure I can pay him by the pint!
« Reply #5 on: May 12, 2012, 11:10 PM »
No.
Actually not true, I have used with good effect metal fillers on frame that have then been powdercoated Metalfil is one such filler.
