975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:34 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bottom bracket
Author Topic: Bottom bracket  (Read 770 times)
Goonio
Bottom bracket
« on: May 10, 2012, 09:31 PM »
Evening -
Anyone got any tips on how this bottom bracket comes apart - there are no spanner opportunities on either side
Bike is a Standard byke 250
Jaypeg
Re: Bottom bracket
« Reply #1 on: May 10, 2012, 09:56 PM »
I don't have much luck when it cones to giving advice.. But it looks like you should take the spacers off and knock the spindle out(I use a plastic hammer to knock mine in). Then you are left with your cups to just knock out. You could take it to a bike shop and get them to do it, they could press a new one in as well. Might be best to see what the experts on here say but that's what I would do. I always find an old seat post useful for knocking out cups. Good luck...
Offline Betty
Re: Bottom bracket
« Reply #2 on: May 10, 2012, 09:59 PM »
Hammer and socket set extension bar  :daumenhoch:
Let's have a look at the old Standard   8)
2 minutes turkish...
Re: Bottom bracket
« Reply #3 on: May 10, 2012, 11:14 PM »
What he said ^^^^^^
Pop those washers off and knock the axle through, then go at the bearings from t'other side with a suitable drift (socket extension if you don't have a long punch). The bearing and it's cup will come out as one.
Goonio
Re: Bottom bracket
« Reply #4 on: May 11, 2012, 12:40 PM »
Thanks for the advice all I'll have a go at that tonight
Re: Bottom bracket
« Reply #5 on: May 11, 2012, 12:47 PM »
Don't be scared to give it a good whack - they can be tight. I always run the bolt back into the axle and hit that to save damaging the splines on the axle  ;)
Offline Devilock
Re: Bottom bracket
« Reply #6 on: May 11, 2012, 01:53 PM »
Re: Bottom bracket
« Reply #7 on: May 11, 2012, 06:59 PM »
A lot like that yeah!
