975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 04:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Kashimax Aero Restoration
Author Topic: Kashimax Aero Restoration  (Read 7189 times)
Tidelander
« on: May 10, 2012, 06:36 PM »
Thought I would share pics of my restoration of a gnarled up Kashi.
Rails were rusted - oxalic soak and then rub with aluminium foil put them right. The plastic however was ripped up with deep scratches down the sides
Actually doesn't look bad from this angle, but the sides were pretty destroyed  ???
Sanded the deep scratches out using a hand power sander and 120 sandpaper then progressive sanded at finer grades until a final final wet and dry sand
Grab one large pot of water - enough to cover the saddle. I used 1 bag of salt, 1 liquid RIT and 1 box of RIT dye powder.
I should add that my misses was out otherwise I'd be dead-man-walking for using her kit  ::)
Heated water up to just below simmering and in the saddle went. I left it in the heated water for about an hour and then took it off the stove (carefully) and left it overnight
This is what came out of the pot
Then a plastic polish using Xerapol plastic polish acrylic scratch remover and a buffer wheel on a drill to get a great finish
The final product, some new decals and a new lease of life  :daumenhoch:
NathanRelton
Re: Kashimax Aero Restoration
« Reply #1 on: May 10, 2012, 06:39 PM »
That looks fantastic, will give that a go!
Offline Devilock
« Reply #2 on: May 10, 2012, 06:44 PM »
Top work... :daumenhoch:
Jaypeg
« Reply #3 on: May 10, 2012, 08:03 PM »
Awesome job... Could be a side line for you :)
« Reply #4 on: May 11, 2012, 07:54 AM »
good work!!!
the only problem i see is its lost its textured finish to the top part, you can get textured finish aerosol paiunt though...   :daumenhoch:
« Reply #5 on: May 11, 2012, 07:57 AM »
Good job  :daumenhoch:
deeman
« Reply #6 on: May 11, 2012, 06:36 PM »
nice work.....if a little slippery!! :daumenhoch:
Offline CustardLips
« Reply #7 on: May 11, 2012, 08:58 PM »
Excellent work.  :daumenhoch:
"WWG1WGA"
Tidelander
« Reply #8 on: May 11, 2012, 09:34 PM »
Yeah, you're right the textured top is sacrificed - was a bit nervous using textured paint in case it looked a bit homemade crafts project ;D  Never had a great experience with rattler cans but if anyone has a bright ide how to get the texture back without any paint skills required - rock and roll!  :daumenhoch:
Gibber!
« Reply #9 on: May 13, 2012, 09:12 PM »
Do you know anyone that has a media blasting cabinet? That works a treat, just mask off the sides and sand blast the top.
« Reply #10 on: May 13, 2012, 09:37 PM »
top work  :daumenhoch:
I would like to know ways to get a good org finish on a flat sanded kashi as well  ;)
Tidelander
« Reply #11 on: May 13, 2012, 10:02 PM »
Nice one - never thought of that. Off to find somewhere with a cabinet  :daumenhoch:
deeman
« Reply #12 on: May 14, 2012, 09:28 AM »
sounds like a good idea,might need redying afterwards though! :daumenhoch:
Offline Glynnyboy
« Reply #13 on: May 14, 2012, 04:54 PM »
Vapour blasting works a treat but the seat needs dying after. A buddy of mine over on bw did this the other week and had some excellent results.
Vapour blasting is also a good idea to get the mottled finish on a polished suntour seat clamp before sending it of for re annodising. :daumenhoch:
« Reply #14 on: May 14, 2012, 07:03 PM »
got link Glynny
deeman
« Reply #15 on: May 14, 2012, 11:49 PM »
So,is vapour blasting the same as aqua blasting?? :idiot2:
Offline Glynnyboy
« Reply #16 on: May 16, 2012, 04:42 PM »
got link Glynny
I went round to see him (butts) B and saw the result round at his house, it hasn't been posted on the forum.
I will ask him the in's and out's.
Offline Orange777
« Reply #17 on: May 16, 2012, 10:25 PM »
A M A Z I N G !!!!!!!!!!!
Inspirational restoration...
Really keen to understand about plastic dyes
Offline kdw712
« Reply #18 on: May 16, 2012, 11:32 PM »
 :4_17_5:
wow great stuff
cheers Kev
