975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 03:42 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear skyway axle problem
Author Topic: Rear skyway axle problem  (Read 977 times)
Webby20001
« on: May 07, 2012, 07:48 PM »
OK, I'm at a loss, I now know i should have taken a picture when I was taking it apart.
Stripped the axle out as i got the hub pulled out again, now I'm trying to put it back together but can't remember what goes where. I did think i would be able to look at my other set but the axle seems to be different?? All the bearings are loose on this set and not the others.
Any ideas?
last pic is axle from my other rear alloy tuff.
Any help would be good  :daumenhoch:
Re: Rear skyway axle problem
« Reply #1 on: May 07, 2012, 11:02 PM »
Right put a dob of grease inside around the cup - this is so the loose bearings have some thing to stick to - you need to count how many (can't remember how many off hand ) for each side
the with the axle - put one cone nut on it (the big nut with curved front) the shields  go over the cone nut (i see you have one on already) - there seems to be the original cover missing
this will lock the bearing down
grease up the other side and bearing in - the cone nut down the axle up to the bearings
then it's a small hex nut up to each cone nut - these now need to be dial in - tighten one side up to each other - then the other cone nut goes up to the bearings and other nut up to the cone nut - you need to have a play on how tight it is and needs to spin - then it's on the forks and washer and nut to tighten
and now for the pic's - hope this helps - cheers B  ;)
Webby20001
« Reply #2 on: May 07, 2012, 11:16 PM »
Cheers Bendy. I thought they were missing the covers as well, I've got another set which have the covers on.  I've managed to get it back together which the bits I've got, have a feeling the axle is from a different wheel though.
Got this off someone on RB.com
[/quote]
I don't suppose I can get the caps from anywhere can I?
« Last Edit: May 07, 2012, 11:23 PM by Webby72 »
« Reply #3 on: May 08, 2012, 12:21 AM »
put a shout in the wanted section  ;)
see what it looks like the covers you have ?
waza007
« Reply #4 on: May 09, 2012, 01:00 PM »
that axle looks bent
