975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 12:25 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Profile mini shims
Author Topic: Profile mini shims  (Read 4749 times)
Mdbh
Profile mini shims
« on: May 07, 2012, 06:09 PM »
Any body put the shims in the rear wheel to stop the wobble? I got some, do they go behind the driver?
HEYWOOD BMX
Re: Profile mini shims
« Reply #1 on: May 07, 2012, 06:29 PM »
 :) Explain further please. :daumenhoch:
Mdbh
« Reply #2 on: May 07, 2012, 06:34 PM »
Profile mini cassette hubs can sometimes develop a slight wobble or play so they supply a very thin shim to stop this, I'm just wondering if the shim go's behind the driver because there is already one there so sounds like its to beef that 1 up a little bit...?
Offline kuwahero
    • Western Titans
« Reply #3 on: May 07, 2012, 06:39 PM »
is the shim thinner or thicker than the one already there?
they also do wafer thin ones which go behind the axle bearings
as above more info/pics required
Mdbh
« Reply #4 on: May 07, 2012, 06:43 PM »
it is wafer thin fella? But I'd of thought just putting up with the og should get rid of slack or should go behind the bearings?
HEYWOOD BMX
« Reply #5 on: May 07, 2012, 06:55 PM »
 :) I`m using a 1mm shim behind the cog on my mini race cog to correct the chainline,hub is 18 months old & no probs so far.
Mdbh
« Reply #6 on: May 07, 2012, 06:58 PM »
Mines only a very slight wobble it feels like loose cones but there not loose!?
Offline Betty
« Reply #7 on: May 07, 2012, 07:44 PM »
I have the same issue with mine
Put it down to grind damage to the hub shell  :-\
2 minutes turkish...
Offline kev-s
« Reply #8 on: May 07, 2012, 08:03 PM »
dont get this prob with proper hubs ;) :LolLolLolLol:
Offline kev-s
« Reply #9 on: May 07, 2012, 08:09 PM »
« Last Edit: May 07, 2012, 08:15 PM by kev s »
Mdbh
« Reply #10 on: May 07, 2012, 08:19 PM »
No they just snap! Had em last about 6 months! Lol
Oh and thanks for the link Kev!:)
Offline kev-s
« Reply #11 on: May 07, 2012, 08:25 PM »
a simple google search was all you needed to do :daumenhoch:
what the fook were u doing to them!!
mine are nearly 4 years old and still fine and im no lightweight on my pegs :LolLolLolLol:
Mdbh
« Reply #12 on: May 07, 2012, 08:35 PM »
What can I say Kev, I'm hard core! When are we going up waitrose?
Offline kev-s
« Reply #13 on: May 07, 2012, 08:57 PM »
if its wet on weds we can go then instead of the park, hopefully shane, paul, mart and drainer can come along too
elevensies
« Reply #14 on: May 17, 2012, 07:48 PM »
If you have a wobble, you have broken a bearing, take them out and check around the outside, I fookin hate profile for this, I must go through one bearing a month on a ss 10mm rear,
I have other issues with other profile hubs I have, I honestly don't know why...
But anyway, that shim, it goes behind the driver, keeps the driver from rubbing on the inner shell.
The other thing is, are you running female axle or male, and if it's female is it the steel or alloy version, as the axle stubs have different threads.
revcore
« Reply #15 on: July 27, 2012, 09:29 AM »
I had the same wobble in my Profile Mini hubs too. I put new bearings in the hub shell and the driver along with new shims but still the wobble remained....Couldn't be bothered with it anymore so I sold the hubs dirt cheap just to get rid of them.
