975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:30 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tech 5s too tight
Author Topic: Tech 5s too tight  (Read 802 times)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Tech 5s too tight
« on: April 29, 2012, 11:27 PM »
Any tips for getting these bad boys on without scratching my bars to bits?
Chris  :daumenhoch:
Re: Tech 5s too tight
« Reply #1 on: April 30, 2012, 12:32 AM »
pliers - put inside a use some man power to stretch it by pulling pliers arms out  ;)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #2 on: April 30, 2012, 12:43 AM »
B to the rescue again  :4_17_5:
I don't think Dia Compe tasked their best engineers when designing these...  ;)
Chris
« Reply #3 on: April 30, 2012, 12:52 AM »
It's a pain but should work  ;)
friday thinking  ;D  design and then i can go to the pub  :crazy2:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #4 on: May 08, 2012, 12:56 PM »
I came up with an even better and much easier solution to the Tech 5 problem...
Take 2 M6 bolts and one M6 thin nut that you can squeeze into the gap in the brake clasp.
Tighten the lower bolt (closest to the lever) into the nut but not past it into the threaded side.  Now tighten the other bolt into the threaded side of the brake clasp - when it meets the opposite bolt a few more turns and it pushes that side open and viola! You can get the Tech 5 on without touching your powder coat.
Now WD your grips on, position the lever and then take out the bolts and it'll grip nicely ready for the correct fixing bolt.
Hope this helps somebody as i tried the Tech 5s on 6 different bars and they were too tight for all of them  ???
Chris  :daumenhoch:
Offline stevesredvxr
« Reply #5 on: May 08, 2012, 07:38 PM »
I just stuck a large flat-bladed screwdriver between the gap and levered it slightly......worked a treat....but don't overdo it as I can see disaster striking.  :)
« Reply #6 on: May 08, 2012, 08:05 PM »
It;s just like watching your children grow  :smitten:
but if yer brake yer legs, don't come running to me  ;D
