975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:22 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Thread help. 9/16 to 1/2 ???
Author Topic: Thread help. 9/16 to 1/2 ???  (Read 617 times)
  • Andy
« on: April 29, 2012, 04:36 PM »
Hi folks. I'm tweaking my Skyway T/A at the moment, and would like to stick a pair of hutch bear trap pedals on it. The only trouble is that I want to leave the one piece sugino crank on the build. Is there any way I can:
1. Change the 9/16 pedals/spindles to 1/2 (either by swapping the spindle completely, or re-machining the thread)?
2. Change the size of the crank thread to 9/16?
Hope someone can help or offer advice.
Thanks.
Andy.  :daumenhoch:
Offline john4130
Re: Thread help. 9/16 to 1/2 ???
« Reply #1 on: April 29, 2012, 04:55 PM »
changing the spindles would be the easiest option if you can get them or changing the cranks to 3piece, i don't think you would have much luck trying to machine pedals or cranks to fit.
Offline Munnyella
« Reply #2 on: April 29, 2012, 05:50 PM »
Use the swap section, you are going the right way to be popular!!
MM
  • Andy
« Reply #3 on: April 29, 2012, 07:07 PM »
MM
 ;D Thanks! The bear traps are re-issue ones by the way, not originals  :(
