975797
Bmxflex
November 16, 2024, 06:05 AM
New School BMX 2004 - Now
Giro questions for KHE **Sorted thanks BENDY**
Topic: Giro questions for KHE **Sorted thanks BENDY** (Read 1224 times)
Sink
April 28, 2012, 04:22 PM »
I think i want to put a giro on my KHE Maceto, being a new school I have no idea whats what, it has holes for removable tabs, so what about the rest? do i just need a regular giro system?
Links etc for whats needed, would help muchly
Thanks in advance
Last Edit: May 01, 2012, 03:33 PM by Sink
fugazi
Site Supporter
540 Air
Re: Giro questions for KHE
April 28, 2012, 05:06 PM »
First thing to do is check to see if the steerer tube is going to be long enough to run a gyro setup, stick a pic up
Sink
April 28, 2012, 06:01 PM »
Don't think space is an issue, 2 spacers under the stem and one on top.
kev-s
900 Air
I bought a site tag and my girth increased by 10%
April 28, 2012, 07:13 PM »
u will need the following, there other versions out there like the odyssey gtx etc...
snafu mobeus gyro http://www.customriders.com/prodshow.asp?prodid=6771&cat=19&parent=1001&sidehop=3
then a gyro plate if your stem dosent have gyro tabs
http://www.customriders.com/prodshow.asp?prodid=14686&cat=19&parent=1001&sidehop=3
then a odyssey m2 lever a cable
http://www.customriders.com/prodshow.asp?prodid=7948&cat=27&parent=1001&sidehop=3
then a dual lower cable
http://www.customriders.com/prodshow.asp?prodid=14685&cat=14&parent=1001&sidehop=3
u can use ur existing lever with a normal upper gyro cable but the m2 set up works very well
kev-s
900 Air
April 28, 2012, 07:18 PM »
or buy this lot off of bendy
http://www.radbmx.co.uk/forum/index.php'topic=143775.0
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
April 28, 2012, 07:22 PM »
yup cheers Kev
yup i have the set up here (above) and at a great price
fugazi
Site Supporter
540 Air
April 28, 2012, 07:34 PM »
Yep, Loads of room, buy that setup off Bendy it's a good deal
Sink
April 28, 2012, 07:39 PM »
I'll take that mr bendy, pm sent p
Sink
May 01, 2012, 02:31 PM »
Thankyou Bendy, arrived this morning, fitted pretty easily and set up 2nd time round, don't know why you had so much trouble with this
No more flappy Linear cable
But do have to get used to using right hand brake again
Last Edit: May 01, 2012, 02:42 PM by Sink
