975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  NS help needed!!! Fork/headset problem
Author Topic: NS help needed!!! Fork/headset problem  (Read 848 times)
Offline WINI
  • Sheeping it real ;-)
« on: April 27, 2012, 07:01 PM »
Just got a set of WTP forks back from SBD (superb job as always), and fit them to my Subrosa DTT with an FSA Impact headset.  Everything seemed to fit fine but when I tightened it all up, there is still some very noticable play in the headset.  Any ideas guys? Help me!!!  :-\
Offline Betty
Re: NS help needed!!! Fork/headset problem
« Reply #1 on: April 27, 2012, 07:09 PM »
Have you enough spacers on Mark?
Tighten the top cap down then undo it and have a look if the top of the fork steerer is flush with the top of the stem, if so bung another spacer in  :daumenhoch:
2 minutes turkish...
Offline WINI
« Reply #2 on: April 27, 2012, 07:14 PM »
New I could rely on you mate  :daumenhoch:
Its flush at the moment, just been to the LBS to get some spacers so I'll try another small one
Cheers bud
« Reply #3 on: April 28, 2012, 07:35 PM »
Be sure the stem sits higher than the steerer by a good couple of mm to allow future adjustments and take a close look at the top cap too. some of them have a lip and sit slightly inside the stem so you have to take that into account too  ;)
Offline WINI
« Reply #4 on: April 28, 2012, 07:42 PM »
Cheers rob, got it sorted now. Pushed the stem down hard against the spacers before tightening and it seems to have done the job  :daumenhoch:
« Reply #5 on: April 28, 2012, 07:51 PM »
Cool.  Do you not have a top cap though?  It's only there to set the headset up..
lk_97
« Reply #6 on: April 28, 2012, 07:58 PM »
Mine doesn't move at all until i put the stem on then it moves about...
Offline WINI
« Reply #7 on: April 29, 2012, 04:26 PM »
Yeah got the top cap.  The stem was quite tight on the fork and I don't think I properly pushed it down against the spacers first time off.  Seems to have done the trick whatever it was anyway.  I'm sure it will need adjustment after the first ride mind  :daumenhoch:
« Reply #8 on: April 29, 2012, 06:24 PM »
Ah yeah, not uncommon. It's been known for people to prise open the stem a bit to get it to drop onto the steerer.
