975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 02:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Motomags - need advice and help and which way to go ? Pic's up
Author Topic: Motomags - need advice and help and which way to go ? Pic's up  (Read 2995 times)
Re: Motomags - need advice and help and which way to go ? Pic's up
« Reply #25 on: April 21, 2012, 12:13 PM »
I imagine the wheel is fine to ride as it is now. Any repair will never be as strong as the original so its all about cosmetics to a large degree. I have used a metal araldite in the past on my car with good results. It files and looks like metal and seems pretty strong.
I would be tempted to add a mechanical element, if the replacement piece allows, by filing a v shaped joint or something similar on the two ends to be joined. If the new piece will hold itself in without any glue then there is less stress on the glue  :daumenhoch:
« Reply #26 on: April 21, 2012, 12:22 PM »
That is great info and just the sort i'm looking for  :daumenhoch: top boy  ;)
also has any one seen a set of highly polished set of motomags - i'm just curious
it's just i want the mags to look a bit brighter and shinny but not too much
any one know what will happen if i put them into acid oxide ? will it clean them up of dark spots - will it just dull them down - will it eat it ? ???
« Reply #27 on: April 21, 2012, 12:32 PM »
Wrong!!!  ;D
Also check this thread, plenty of info. One lad cut all of the webbing out  :shocked:
http://bmxmuseum.com/forums/viewtopic.php?id=253053&p=1
« Reply #28 on: April 21, 2012, 12:40 PM »
hmmmmm i wonder how it would look if you laser cut the webbed bits out of nylon sheet and glues them on some Mk 1 acorns  ;)
 :4_17_5:
Offline kalex
« Reply #29 on: April 21, 2012, 05:30 PM »
the webbing is only there originally to stop kids putting their hands in the wheels, the motomags run ok with all the webbing removed and just the main spokes remaining.
« Reply #30 on: April 21, 2012, 08:01 PM »
But there is some thing ICONIC about the look of them, the silhouette just looks great and the webbing make them stand out  >:D
Offline kalex
« Reply #31 on: April 21, 2012, 10:04 PM »
i agree you can't beat the look of motomags with the webbing intact, here's mine in gold
« Reply #32 on: April 21, 2012, 10:26 PM »
Now that looks really sweet - the black and gold combo is just lush  :smitten:
« Reply #33 on: April 21, 2012, 10:35 PM »
+1 Nice in the gold   :4_17_5:
Quite like this yellow and blue combo too  :D
« Reply #34 on: April 21, 2012, 10:41 PM »
did see some where a set of candy red ones -  :smitten:
